586,679 active members*
2,632 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Taig Mill - need speed control for spindle
    Feb 2005
    5
    Smile Taig Mill - need speed control for spindle
    I'm sure this question has been asked many times before so I'll keep it short and sweet. I have a new CNC Taig mini mill and want to be able to control the cutter speed with the G code (Mach3 software). I ran across a web site last week that had an add on kit but cant see to re-find it. I'm new to this so just point me in the right direction and I'll leave everyone alone.
    -John
    Oct 2005
    6
    That's an AC motor, so you may be stuck with addind a VFD (variable frequency drive). Tha's usually a pretty expensive option, which is why its pursued by the big boys and not hobbyists most of the time. A cheaper option might be finding a fast DC motor and controller then cutting a custom mounting plate option.
    Either solution should have surplus options available, so I'd add the word 'surplus' to my initial searches in the interest of keeping the prices down.
    HTH,
    Kalo
    Jul 2004
    374
    http://www.campbelldesigns.com/mach-...ed-control.php
    Like Kalo said, the expensive part is the 3 phase spindle motor and variable frequency drive. You'll also need load reactor coils, maybe a power supply (for the control board, depending on your VFD), and an enclosure for everything.
    Oct 2004
    168
    homann designs
    You can retrofit a Sherline motor or any KB control and use Peter Homann's digispeed control board
  1. CNC Controlled Spindle motor speed control
    By gregmary in forum CNC Machine Related Electronics
    Last Post: 02-28-2009, 02:01 AM
  2. Taig mill accuracy
    By dberndt in forum Taig Mills / Lathes
    Last Post: 12-29-2004, 04:36 AM
  3. Total Newbie on Taig CNC Mill!!
    By vwgo in forum Taig Mills / Lathes
    Last Post: 10-18-2004, 01:40 AM
  4. MicroProto Taig Mill
    By vayacon in forum Taig Mills / Lathes
    Last Post: 10-14-2004, 09:58 PM
  5. Master5 Taig Mill Setup
    By Jcadwell in forum Mach Mill
    Last Post: 11-09-2003, 12:53 AM
