586,138 active members*
3,836 visitors online*
Thread: yang smv 600
    Oct 2010
    Angry yang smv 600
    i went to do a tool change and the carousel kept spinning around until alarm 1007 appeared. now the spindle is above the carousel like its doing a tool change .
    Sep 2007
    371
    What control does your machine has?
    Nov 2009
    Yang help
    I know itsa little late, but have you fixed this? It's probably one of the three (usually blue) prox sensors that is failing to send a signal. I think you can look at x16.7, 17.7 and 18.7 to see which one. if you haven't fixed it and still need help, I can look up exactly which one when I get back to my shop
    -Brad
    Apr 2011
    Greetings from Finland. I have the same problem. We use Fanuc series 0-MD interface. Apparently the problem is with the proximity sensor also. Model Yamatake-Honeywell FL2S-4J6HD-R5. Problem appeared when changing tool. Whole thing froze and error 1007 appeared. We also thought that the problem could be that the M06 code is active. The problem is that we don't have the original manuals, but only translated ones that don't appear to have all the info we need. Also, it's probable that the main problem is sensor X16.7. If there're any suggestions, I'd be happy.
  1. Yang ML-25A
    By Billet Sean in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2015, 05:48 AM
  2. Yang VMC MV3A
    By susiem in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-24-2009, 06:37 PM
  3. YANG VMC1000 OM-D
    By Toddxmann in forum Fanuc
    Last Post: 08-05-2009, 12:59 AM
  4. yang growl
    By BAD DOG in forum DNC Problems and Solutions
    Last Post: 02-16-2007, 09:11 PM
