586,903 active members*
2,873 visitors online*
Results 1 to 15 of 15
    Sep 2010
    find center point of circle
    hello
    i have a question.In G02 and G03 if we have R value and need to find the point of circle.what do we do? i saw a formul in this site but it did not work correctly
    and i use some formul but i did not an answer.please help...it is very important for me
    Sep 2010
    hello
    please ask my question.how can i find center when i have two points and radius
    in Gcode (G02 and G03) how do i do when i do not have I and J value?
    Please help
    Feb 2007
    664
    you can find sites that teach math with a Google search
    Sep 2010
    thank you
    but i explain that i searched and studid many days but i can not find a correct result.if you know site please tell me
    May 2008
    667
    Machine Shop Info
    This guy offers good video tutorial, really helpful.
    Jeff
    Nov 2009
    23
    Talking Equation Link
    Here is a link to a web site that has the information that you seek.
    Equation of a circle in standard form. How to express a circle with given radius in standard form...
    I hope that this is what you are looking for.
    Sep 2010
    thank you
    but this formul is not correct. It did not calculate center point correctly.I tested
    many foumul but all of them were wrong.
    Sep 2010
    Quote Originally Posted by Medm View Post
    thank you
    but this address is error.I can not see this site.could you that formul mail me?
    1792
    After you make a circle using R-method, why do you need its center. Pl explain.
    I can work out the formula for you, but why devote time on something not very important!
    Pl explain your requirement first.
    Sep 2010
    Quote Originally Posted by sinha_nsit View Post
    hello and thanks
    what do we need for draw a circle?R and center coordinate.so I need to know what is center points.you tell me G02 or G03 draw circle but where does draw it?start point end point Radius and center points are need.if I thinking wrong please guide me.
    sorry my english is weak so I wrote sth wrong.
    1792
    You need to specify either R or IJK, not both.
    If you specify both, the control uses R-method, ignoring IJK.
    Positive R produces minor arc (which is relevant in most cases), and negative R produces major arc.
    The manual does not recommend R-method when the chord angle is close to 180 degree.
    Feb 2007
    664
    i think he is trying to write a program that plots out the tool path
    Sep 2010
    thank you very much.
    you are right.I think I need R and J,I.So now found it is not necessary.thanks
    Sep 2010
    1230
    Quote Originally Posted by Farzaneh_2010 View Post
    Are you wanting this information for use with Circular Interpolation in a CNC program, or are you trying to write a program to plot the tool path of a CNC program? If you are trying to write the software to plot the tool path, I can give you the routine to calculate the circle center when given two points and a radius. If that is what you require, please reply and I will post the code and an explanation on how to implement it.
    Bill
  1. cant cut a circle? "current point same as end point of arc"
    By maccrazy2 in forum DeskCNC Controller Board
    Last Post: 02-14-2012, 07:15 AM
  2. Find center of circle
    By dano9700 in forum Engraving Machines
    Last Post: 12-16-2010, 02:19 AM
  3. Error in end point of circle.
    By crkdinesh in forum EdgeCam
    Last Post: 11-29-2010, 05:03 PM
  4. Replies: 1
    Last Post: 02-04-2007, 03:33 PM
  5. Find the center of a circle
    By Hobbiest in forum WoodWorking Topics
    Last Post: 01-28-2004, 06:24 AM
