586,817 active members*
6,790 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Y axis servo motor chattering below 100 inches a min!
Results 1 to 12 of 12
    Aug 2010
    I checked the ball screw. Checked oil on the ways. Checked the contacks. Still geting viberation in the table at low feed in y axis. Could it be the servo?
    Jun 2008
    1104
    What machine is this?
    Aug 2010
    Hurco bmc2416 98model Ultimax 3
    Jun 2008
    1104
    Ok. Is it a sort of whining noise that gets worse the further to the front the table gets?
    If so, it may be the thrust bearings have lost their preload or the ballscrew has backlash that is setting up oscillation in the servo loop. You could prove it out by lowering the gain on the servo amp for the Y-axis.
    Have a look in the control cabinet and let me know if one of the servo amps has a little display unit attached to it (about an inch and a half square with an LED display). It'll be towards the top of the servo amp.
    Aug 2010
    Not really a whinning noise when i move the table in y axis. Just the normal sound. The servo amplifiers have no led screen. Just green lights. I will try to post a video tommrow. The table just chaters/viberates at low feed rates. You can see the chatter marks in the parts but it is only in y axis moves.
    Aug 2010
    I tried to balance out the servo this morning in the service mode. This did not work. I am now gonna try and switch the x axis servo with the y axis servo and see if i have the same problem.
    Aug 2010
    Ok bloke changed the servos still have the same problem. Then i went into service mode. Then servo tuning and incresed the gain form one to two. And the viberation got much worse. How do i turn the gain down from one?
    Jun 2008
    1104
    Which parameter did you adjust? You should reduce Proportional gain to reduce servo response.
    I don't have my work laptop fired up at the minute to see what the parameter should be. If you reduce it, it may be worth reducing the X axis gain to suit.
    Edit to add:
    What software are you using in the machine? Press the input key and it will tell you near the top of the page.
    Aug 2010
    I adjusted the y axis paramater. The x axis is smooth as silk. How do I reduce proportional gain? My master program is "mill system version 2.15 oct 26 1999"
    Jun 2008
    1104
    Go to the servo tuning page in the hidden diagnostics (auxiliary, enter, 100, enter, system tuning, servo tuning, standard parameters, Y-axis).
    In the tune parameters, there will be a list that appears on the left side of the screen that should look like:
    Integral
    Proportional
    Feedforward
    Derivative
    and so on. What you will need to change is the value in Proportional (make a note of the original value so you can go back to it if needed).
    When done, keep pressing "exit" until it says about saving the changes - press yes and continue to exit until you are back at the auxiliary page.
    If necessary, go back in and reduce it further until the vibration stops.
    Aug 2010
    Bloke your the best, that fixed it. Still got a little bit of a bump when changing direction. But i think that is normal. Thanks for helping a yank out.
    Jun 2008
    1104
    Glad to hear it, fella!
    Have a good weekend.
  1. Need Y-axis servo motor
    By bucky898 in forum Charter Oak Automation Support Forum
    Last Post: 07-16-2010, 09:33 PM
  2. Z axis servo motor getting really hot
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 03-10-2010, 02:53 AM
  3. i got a problem with Y axis servo motor.
    By tarikk in forum K2CNC
    Last Post: 07-04-2009, 04:36 PM
  4. X Axis Servo Motor Overheat
    By mtgpaul in forum Colchester Tornado lathes
    Last Post: 10-18-2008, 01:37 AM
  5. Servo motor for Lathe & 4th axis
    By skip20 in forum Mini Lathe
    Last Post: 04-16-2008, 04:02 PM
