587,065 active members*
3,881 visitors online*
Results 1 to 9 of 9
    Feb 2010
    3447
    (4) pieces of 1/2" plate machined ASAP. RFQ
    I need a rough estimate on how much these would cost to machine. Everything can be cut from 1/2" aluminum plate. Overall dimensions are shown in the pictures for simplicity. If you need more specifics please Private message me. I need a ballpark price. Some of the holes need to be tapped after machined. If you can do this as well it would be a plus but not required whatsoever. The inside square corners i can fillet or chamfer as well if that makes it easier for you to get a endmill in there. please advise. I can modify to accommodate. Plans are 95% done. Very slight modifications will be implemented. I will send you the final plans via email, or post them up in the next few days. For the sake of time though, please shoot me a rough quote.
    I need this done asap. It converts my cnc mill X axis from ballscrew to rack and pinion drive.
    Here is a link to the huge thread i have posted about the rebuilding of my machine if you care to read.
    http://cnczone.com/forums/showthread.php?t=103291
    Thanks!!!!
    Attached Thumbnails Attached Thumbnails Part 1.png   Part 2.jpg   Part 3.png   part 4.png
    Jan 2010
    62
    pm sent
    Feb 2010
    3447
    Hopefully today i will get the plans posted. I HATE 2D Drawing, so bare with me.
    Sep 2009
    313
    PM Sent..
    Feb 2010
    3447
    Updates:
    Added Radius to inside corners.
    Fully defined sketches.
    Finalized plans.
    Attached:
    One Zipped up folder.
    Contains (2) pictures:
    Assembled picture
    Exploded assembly
    Contains (4) PDF documents, one to each part:
    Flange Top
    Flange
    Motor Flange
    Spacer
    Please take time and check over the plans to make sure i did not miss a dimension you will need.
    Attached Files Attached Files
    Feb 2010
    3447
    If you have Solidworks and would like the the files as well, please email me and i will send you over the zipped up parts and assemblies folder. It contains all the drawings as well as the full 3D files. It is roughly 5-6 Megs in size.
    Please bring any missing dimensions to my attention.
    Thank you.
    diyengineer AT Gmail dot com
    Sep 2010
    Can you please send the prints to [email protected] so we can work out a quote. Thank you.
    Jan 2010
    62
    send the files to me as well. thanks.
    [email protected]
    Feb 2010
    3447
    I am going a different direction. Instead of 1/2" 6061 Aluminum I need someone to use a router or mill to cut the parts from MDF or plastic (1/2"). You can buy a whole sheet of MDF just about at any lowes store or home depot for $20 bucks.
    I'm going to start a new thread, consider this one dead.
    Going to use the routed pieces as a mold and cast them out of aluminum using green sand which i have had great results doing. This opens up the job to almost anyone with a router cnc. The holes do not need to be tapped just bored through as indicated.
    Since this changes things up a bit please Re-apply in the new thread of PM me.
    thank you very much!
  1. Cold-rolled steel plate, 13"x24", 1/2" thick.
    By Odin in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:00 AM
  2. .125" AL plate, cut (mill or laser), bent .125" ID bends
    By Sporqster in forum Employment Opportunity
    Last Post: 09-23-2008, 09:41 PM
  3. 4 or 8 pieces "Simple Aluminum hdd tray"
    By snowcnc in forum Employment Opportunity
    Last Post: 06-09-2008, 01:54 PM
  4. RFQ: pieces of 0.5" baltic birch plywood in LA
    By gmed in forum Employment Opportunity
    Last Post: 09-03-2007, 10:27 PM
  5. Rfq Machined Aluminum Plate
    By Philip in forum Employment Opportunity
    Last Post: 08-22-2006, 04:15 AM
