586,301 active members*
3,813 visitors online*
Thread: Fagor DRO
Results 1 to 7 of 7
    Dec 2009
    5
    Fagor DRO
    I just got an IH 12Z mill and am trying to learn how to use the Fagor DRO. I am having difficulty understanding some of the functions of the DRO, and the Fagor manual is not very helpful. One example is the corner rounding function, where you enter an X and Y end point, radius, and quadrant. I can get this to work but not reliably. Does anyone have an improved manual for the Fagor DRO? The DROPROs video on cornor rounding is very straightforward compared to the Fagor. Any help would be appreciated.
    Jul 2010
    14
    Is it the 40I
    Dec 2009
    5
    I should have mentioned I have the Fagor 30i model DRO.
    Jul 2010
    14
    I have the 40i but I think the functions are similar. Did you setup all the parameters like tool radius comp and reverse counting? I too have been challenged with those crappy instructions and fagor USA has really no support, well for the 40i that is.
    Dec 2009
    5
    Fagor DRO Setup
    I set the DRO up so that the left front corner of the workpiece is 0,0 and as the tool moves to the right on the workpiece the X count increases, and as it moves to back of the workpiece the Y count increases. Is this how a DRO is normally set up? I also enter the diameter of the tool. I tell the DRO that I'm touching the tool to the left of the workpiece and clear the X axis, and then that I'm touching the bottom of the workpiece and clear the Y axis.
    I think understand a little more about how this thing works. I may put together some notes, as it looks like it might help others too.
    Jul 2010
    14
    Mine is setup where the y axis moves toward the column and the x moves right the #s go -. I'm not even sure if this is correct. Maybe the good fellas in the Fagor forum can shed some light for us.
    794
    Normally the zeroing of the table axis for homing is done with the table closest to column and to the right in operator view. The spindle without any tool is zeroed just kissing the top of the table. Then all WPO's & all TO's calculate from that point. I take it one step further and keep G54 clear for tool touch off values. This way I can manually touch off any replacement or added tooling without interference with Work Piece Offsets botching the Tool Offset. I have set the Z up with touch to table, then home it against switch with auto zero turned off on the z. That way I can read the position from dro and install it in the homing set up and turn the auto feature back on and after ward with a clean spindle I can home and MDI a G0 Z0 and the spindle will rapid down and stop just kissing the table top.
    The travel of the table is to be considered as the TOOL moving, not the table. So if the table is moving to the left, the tool is moving positive.
    Don
    IH v-3 early model owner
  1. CPU Fagor + LCD
    By politecnica in forum Brazilian Club House
    Last Post: 01-02-2015, 05:57 PM
  2. new here..fagor help?
    By cncsed in forum Community Club House
    Last Post: 07-29-2010, 04:52 PM
  3. FAGOR
    By fsantos in forum Want To Buy...Need help!
    Last Post: 03-18-2009, 02:10 AM
  4. fagor help
    By shimmwagen in forum Fagor Automation
    Last Post: 12-18-2005, 05:56 AM
