586,358 active members*
3,616 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Super-PID new low-cost router speed controller
Page 2 of 121 12341252102
Results 21 to 40 of 2415
  1. #21
    Mar 2010
    621
    Quote Originally Posted by RomanLini View Post
    Super-PID closed loop speed control; This has a infra-red speed sensor pointed at the router shaft, so it measures the exact RPM of the router at all times. Then it uses a high-speed math algorithm called P.I.D. to adjust the power sent to the router, to keep the router spinning at the RPM you wanted. And it has an accurate tacho so you can set a chosen RPM based on speeds/feeds tables as people need for professional production.
    So, if I understand you correctly the PID creates low adjustable RPM with same power/torque?
    Does that mean a traditional speed controller just cuts the power to the router to control the speed?
    Adam,
  2. #22
    ger21- Sure it should not be a problem. You would need one relay to changeover the router power (2 wires) and another relay to changeover the sensor (2 wires). Or, you could just have 2 plugs and plug in the router power and the spindle sensor for the desired router. I just have an AC mains line plug on mine, and a 3pin small connector for the sensor.
    It seems an unusual request, I'm guessing you have 2 routers set up and need to use both regularly?
    I'm building a router with 2 independent spindles. Two fixed speed routers and the Super PID would be about the same price as the two VS routers I was looking at.
  3. #23
    Mar 2010
    275
    pid code
    Hey Roman, I've been following you for a while and you do some really cool stuff!
    Just curious, did you code the PID algos or is there something in the public domain?
    Also, can you recommend any reading for those of us starting to climb the rather steep learning curve for PID?
    Thanks, and keep up the good work!
    -Jim Hart
    My main machine: Multicam MG series (MG101) with original Extratech H971 controller, Minarik servo motors, Electro-Craft BRU-series drives, 4KW Colombo. Let's talk Multicam!
  4. #24
    Oct 2005
    2392
    Quote Originally Posted by adam_m View Post
    I wouldn't say the "same" power at all RPM because the router naturally has a lot more power at high RPMs. But the Super-PID will increase the power to keep the RPM the same, so you can actually do cutting at quite low RPM (which is just not possible with a standard variable speed router).
    And yes, traditional (open-loop) speed controllers just cut the power a bit and are only useful when in the router's sweet spot, ie quite high RPMs.
    Ger21- Ahah I understand now. I would go for the 2 routers+Super-PID just to get the big performance benefits.
    Boltz- Thanks for the compliemnt! And although I have put in a lot of work on open-source projects in the past (to give back to the world) and plan to still do so in the future, this particular project is a commercial one.
    I have around 200 engineer hours invested in Super-PID so far and Val (the product owner) has a few grand invested in parts, production setup and lots more to spend yet on labour and advertising etc, so we need to sell quite a few of these to break even. And of course you would understand that means we would really NOT be wanting to help anyone compete. Some things are for giving away and some things are for making a living from.
    And just while we are on the topic, this forum has specific rules about piracy of intellectual property and if anyone tries to hack/reverse engineer the Super-PID intellectual property I will be asking forum moderators to delete posts.
  5. #25
    Will the Super-PID allow me to run a 23,000 rpm router at 30,000 rpm?
    An 11 amp router #120V is~1300watts. I'm assuming it won't be drawing the full 11 amps most of the time, so it should be fine?
  6. #26
    Jun 2010
    I'm pretty sure that the top speed of AC motors depends on the physical properties of the motor, such as the number of windings in the coil, so no. You will be able to set it to 30,000 RPM but the motor will just reach its max 23,000 RPM.
    It's a bit like a light dimmer, for turning down brightness of lights. You can turn down a 100W globe to shine like a 60W globe, but if you put in a 60W globe, it can only ever shine as bright as a 60W globe, even if the dimmer is set to max.
  7. #27
    Oct 2005
    2392
    Ger21- Sorry (as JeremyFisher said) the router's max RPM won't be exceeded, provided the labeled max RPM is in fact the no-load RPM. Some router's labeled as 25000 RPM etc will run a bit faster on no-load and light cuts as the official RPM rating is when cutting wood with a cutting bit.
    Re the 11 Amp 1300W router, I have initially specced the Super-PID lower than its calculated limits. The connector, PCB traces, TRIAC etc (all the parts that carry motor current) are rated at 15 Amps or more but I have specced at around 10 Amps for now until the product has undergone significant testing over time.
    When in use, the SuperPID will generally use MUCH less than full power, and it has a power bargraph display on the LCD so you can see the power % anytime it is running. The product was designed specifically for routers up to and including 1200W or so which is a popular size.
    I'm in the final stages of product testing now with the proper PCB (up to now has just been prototype units) and it's all looking good.
    I have borrowed a video camera and if I get time today or tomorrow I'll do a youtube of the product demonstrating the low speed power!
  8. #28
    Mar 2010
    621
    Definitely interested in some video of the product at work at different speeds and materials..
    Adam,
  9. #29
    May 2005
    162
    Hi Boltz,
    Have a look at Microchip Technology Inc. is a Leading Provider of Microcontroller and Analog Semiconductors, providing low-risk product development, lower total system cost and faster time to market for thousands of diverse customer applications worldwide., search for PID, they published pid algorithms for use with their range of microprocessors back in 2004, possibly much earlier, I was using pid myself back in 1995 for control of neonatal oxygen controllers.
    Here's a link to a specific doc: http://ww1.microchip.com/downloads/e...tes/00937a.pdf
    David
    ( never stop learning )
    http://www.steamcastings.co.uk/
  10. #30
    Apr 2009
    149
    ME TOO ! ! !
    The product target price was to be under $150 for the fully assembled unit, possibly it could be as low as $120 or $130 but costing is still waiting . . .
    I want one! Please put me on your email list or whatever you are doing to keep track of future customers.
    [email protected]
    Thanks.
    tjskcnc
  11. #31
    Oct 2005
    2392
    Thank you tjskcnc, I'll pass that along to Val, the product should be available for sale next week. I'm sure he will announce something soon.
    The new test unit (on the commercial PCB) is working very nicely, and here's a photo of the first 3 units to go out, which should be tomorrow after I run a series of tests on them.
    They are going to Khalid, CarveOne, and Ger21 and have a couple of rough edges because they are not from a "proper" production run yet, like the heatsink brackets were just cut on the chop saw etc. But they are quality units; stainless steel screws, metal film resistors, tantalum caps, plug/socket on LCD, etc etc.
  12. #32
    Do we need to solder the pot to the board?
    And for Mach3 control, do we not use the pot, but use the same terminals?
  13. #33
    Apr 2007
    8082
    Thanks!
    I'll be looking for it to arrive. Don't worry, the rough edges won't look out of place around my shop.
    CarveOne
    CarveOne
  14. #34
    Mar 2010
    621
    Can't wait to hear the review from Carveone and the others...
    Adam,
  15. #35
    Apr 2006
    3498
    Hi RomanLini,
    Thanks for showing the stuff and i am very excited as in coming months i have to use my Router a lot as we have community Funfair charity show in January..
    We have 220Volts here but the frequency i will tell you tomorrow...
    Thanks and Regards
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  16. #36
    Oct 2005
    2392
    The units were sent airmail today, apart from Khalid (please PM me with your address Khalid!).
    Ger21- The pot and sensor are supplied and all wired up now (but not in the photo).
    As for running the speed control from Mach3, I'm glad you wanted to test that because it's something I can't do here. The middle wire of the pot goes from 0v to 5v, and that gives speed control of 5000 to 30000 RPM. However it's not totally linear as the scale was carefully adjusted to a semi-log scale to give better "feel" of the pot. It can still be controlled from any 0v-5v analog source if Mach3 has that type of analog output.
    If the Mach3 output is 0v-10v you need to add two 10k resistors as a 2:1 voltage divider, that is easy enough. I'm not sure how mach3 can recalibrate for the semi-log scale though, I'd appreciate if anyone can offer more light on the whole process there. If you need more info I can provide a table showing pot voltage vs set RPM.
    CarveOne- When I said rough edges that's basically saying these initial units are made here in the design workshop and the overall finish is not representative of a proper production batch. But they are complete and fully functional with all the stuff that matters (as is your workshop I bet!).
  17. #37
    Apr 2007
    8082
    I was just joking with you. Everything around here has rough edges on it, including the owner. I know how engineering lab work goes as well. Been there and done that for too many years.
    CarveOne
    CarveOne
  18. #38
    Ger21-
    Actually, I can't test it either. I'll need to add a parallel port and an additional board to generate the 0-5V signal. Something like this:
    DC-03 DigiSpeed GX V3 [DC-03] - US$38.00 : Homann Designs, The Preferred CNC Component supplier
    or this:
    CNC4PC
    Not sure if I have room in my box, though.
    Looks like the voltage is linear, so I'm not sure if or how Mach3 can compensate.
  19. #39
    24222
    Don't these BOB's that offer Mach (PWM) to VFD analogue, provide this?
    They usually offer 0-10vdc, but I believe it can be scaled in Mach just going by an Email I got some years ago from Art when I looked into making one.
    Al.
  20. #40
    Apr 2007
    8082
    My CNC4PC C11G breakout board has the 0-10vdc spindle speed control function on it. I'll see if I can make it work.
    Maybe future boards can have a switch or jumper to select linear (Mach3) or nonlinear (potentiometer) mode options.
    CarveOne
    CarveOne
  1. Harbor Freight router speed controller fix
    By mickelsen in forum CNC Machine Related Electronics
    Last Post: 01-25-2012, 03:46 AM
  2. Super-PID speed controller installation to Fixed speed Router
    By Khalid in forum DIY CNC Router Table Machines
    Last Post: 11-13-2010, 11:29 AM
  3. Super-PID router speed controller
    By SuperPID in forum News Announcements
    Last Post: 10-21-2010, 05:40 PM
  4. I need a low cost upgrade controller for my CNC Router
    By ReefkeeperCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-09-2006, 02:01 AM
