586,401 active members*
3,073 visitors online*
    Sep 2010
    8
    Bar Puller Program Problem
    Any help would be great. I have a Hitachi Seiki 20SIII Lathe, Seiki-Seicos LY controler. I have been running the machine for two years now and just purchased a Dunham bar puller. Programmed the machine for the bar puller but I am having a problem with the Z axis not wanting to move with a G01 with the spindle stopped with a M05. Is there an M Code or G code to override the M05 to get the machine to move with the spindle stopped?
    Feb 2009
    6028
    You need to be in IPM mode. Lathes usually default to IPR. G94, G95...
    Jan 2007
    52
    here is a sample program for the bar puller that we use (Royal Products CNC Bar Puller). We use this in several machines ,usually just changing the M-Codes for opening/closing the collet.
    G0G56G18M9
    G0T1212M5 (TOOL CALL UP)
    G98G0X3.Z.1 (APPROACH PART, ABOVE PART)
    Z-3.35 (MOVE TO BAR STOCK THAT IS STICKING OUT OF COLLET)
    G1X1.35F200.
    G98G1X-1.F150. (ENGAGE PART WITH BAR PULLER)
    G4U.1 (WAIT)
    M11 (COLLET OPEN)
    G4U.1 (WAIT)
    G98G1W3.11F150. (PULLING BAR OUT REQUIRED LENGTH)
    G4U.1(WAIT)
    M10 (COLLET CLOSE)
    G4U.1(WAIT)
    G98G1X1.5F200. (DISENGAGE BAR PULLER FROM PART )
    G99G0X6.Z3. (CLEARANCE MOVE)
    M30
  1. Which bar puller do you use.
    By 123tool in forum Haas Lathes
    Last Post: 02-16-2010, 11:40 PM
  2. Bar Puller VS Bar Feeder
    By inertialabs in forum Haas Lathes
    Last Post: 12-10-2009, 09:38 PM
  3. sub program problem
    By 5xphil in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-05-2009, 03:54 AM
  4. program problem
    By settingbur in forum CNC Swiss Screw Machines
    Last Post: 03-22-2008, 03:26 AM
  5. CNC lathe plus Bar Puller help
    By SeaSchell in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-06-2006, 12:44 AM
