587,004 active members*
2,779 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > prep work for anodizing
    May 2009
    33
    Im curious to see what everyone else who works with aluminum does to prep their parts for getting them anodized. I just recieved back my first ever anodized aluminum part and wasnt satisfied with the finish. I own some aluminum parts that have been anodized and they all have a nice matte finish on them, and thats what im after.
    Its T6 6061 Alum. and what i did was buff them with scotchbrite pads that attach to a 90° die grinder. And all those buffing marks showed thru the anodize.
    Maybe im using too aggressive of scotch brite pad???
    What kind of abrasives should i be using??
    Thanks in advance
    Jul 2005
    12177
    You should be posting a query like this in this forum which is for finishing, however it is difficult to find:
    http://www.cnczone.com/forums/forumd...ysprune=&f=280
    To get an even matte finish you will probably have to use a tumbler or bead blasting. Trying to do it with scotchbrite is difficult because for an even appearance you have to have scartches running in all directions. Using a die grinder is too fierce and because all the marks are in line they really show up after anodizing.
    Go and read through the threads in the link I gave and you should be able to dig out some information.
    May 2009
    33
    Geof Thanks a ton
  1. Shop Prep Questions For Setting '08 VF-2 w/SMTC
    By l u k e in forum Haas Mills
    Last Post: 10-25-2013, 03:40 PM
  2. Indexable Angle, Conical Mill & Web Prep Cutter
    By CDTooling in forum News Announcements
    Last Post: 08-22-2010, 10:29 PM
  3. X2 MINI MILL TEARDOWN & PREP GUIDE
    By Crevice Reamer in forum Benchtop Machines
    Last Post: 12-10-2009, 05:19 AM
  4. Sink Undermounting (Prep)
    By JoeGranite in forum Glass, Plastic and Stone
    Last Post: 05-28-2008, 02:40 PM
  5. lead screw prep and maintenance
    By jp_dt in forum Linear and Rotary Motion
    Last Post: 02-07-2008, 07:39 PM
