586,124 active members*
3,006 visitors online*
    Mar 2010
    Hardinge VMC 600II Power Up Problem
    Hardinge VMC 600II, with Fanuc 18 0-MD control.
    We just had a power "flicker" and now my machine control will only boot up to the date of manufature screen and has blinking (and beeping) alarm "NOT READY".
    I have held down the LPQ and Cancel keys while powering up but that didn't help.
    I noticed the Spindle Amplifier Module ( inside the main power cabinet ) will show 12 as soon as main power is switched on, then switch to 3 after a second or so, then switch to two flat blinking lights .
    When I shut down the control (but still have main power turned on ) the Spindle Amplifier Module display switches to the number 24 and indicates an alarm.
    Jul 2011
    Hi, I have a very similar problem. have you managed to get your machine running again? Can you share what the cause was and offer a solution. Regards.
  1. Hardinge CNHC I Startup problem
    By outsource in forum Hardinge Lathes
    Last Post: 06-06-2009, 04:00 AM
  2. Hardinge T51 turret problem
    By gtsraven in forum Fanuc
    Last Post: 04-13-2009, 12:52 PM
  3. hardinge conquest 51 problem
    By bassmastrbw96 in forum Hardinge Lathes
    Last Post: 09-05-2008, 02:39 AM
  4. Replies: 11
    Last Post: 07-10-2007, 11:42 PM
  5. HELP!!! Smoked Spindle on Hardinge VMC-600II
    By Janos in forum Bridgeport / Hardinge Mills
    Last Post: 01-19-2007, 06:59 PM
