586,377 active members*
2,421 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Need to start in the middle of my program
    Sep 2010
    im using a Haas TL-3B and im trying to start on a line thats in the middle of my G-Code. we also have a TL-3 and i can do it just fine on the same program. im wodering if theres a paramiter or setting thats prohibiting me from starting in the middle of my code. im attaching a txt file of the code. i want to start on line 536 where it says:
    (TOOL - 8 OFFSET - 8)
    (OD THREAD RIGHT INSERT - DT-60DEG-.015R)
    thanks!
    TJ
    Sep 2010
    forgot to post attachment... :-p
    Attached Files Attached Files
    Jun 2005
    138
    http://linuxcnc.org/handbook/gcode/g-code.html
    You could simply delete all the motion operations from the start of the file to that point, "Save" the file under a new name, then run it. Be sure to keep your machine setup operators in there, like the speed settings, workpiece co-ordinates, etc.
    2932
    Setting 36?
    Aug 2009
    235
    Yeah setting 36 is what your looking for, and just so you know there are canned cycles for what your doing. Unless you have cam software then it doesn't really matter.
    Dec 2007
    33
    scroll down in edit mode to the point you wish to start, then press memory,
    If you have all the needed g54's and g50's, you should be able to start from there.
  1. VF-2 stops in the middle of a program!!
    By southernexplore in forum Haas Mills
    Last Post: 08-12-2009, 06:34 PM
  2. starting in the middle of a program
    By panaceabea in forum Milltronics
    Last Post: 05-19-2009, 02:54 PM
  3. locked up in middle of program
    By nmn in forum Haas Mills
    Last Post: 03-31-2009, 03:33 AM
  4. starting from the middle of a program
    By panaceabea in forum Haas Mills
    Last Post: 03-28-2009, 12:31 AM
  5. Starting in the middle of a program.Old control.
    By lostkoss in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-07-2008, 03:11 PM
