As you can see from the title, I am using a Fadal VMC 3016L. I am also using CAMWorks 2010 for my software.
Whenever I set up the program, I make sure that the machine and the program have the same origin to make things as painless as possible (use a wiggler on the top left corner of the part to coincide with the way that I model the part).
The problem that I am having is that when the program is run the machine is off 0.060in-0.065in in the +X axis.
Any ideas?
