586,337 active members*
3,588 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MasterCam X2 Chamfering toolpath
Results 1 to 8 of 8
    May 2008
    10
    Question MasterCam X2 Chamfering toolpath
    Hi guy, this is my first time trying to do a chamfering toolpath with MasterCam X2, When i trying to generate the toolpath i get these warning ( Entry: ramp Contour, chamfer and 3d are not enabled. Upgrade to level 1 is required. ) what these warning really mean and how to make it work ?
    May 2007
    312
    Quote Originally Posted by nuai View Post
    On the start up splash screen what level does it say you are licensed for?
    May 2008
    10
    Chamfering Toolpath
    Hi foxsquirrel,
    On the start up splash screen it say : ( Design ,Mill Level 3 ,Lathe Level 3 ,Wire EDM Level 3 ,Router Level 3 ) What is these level mean anyway ?
    Dec 2008
    3111
    It means that the info that you just gave is not right.
    Lathe, Router, and Wire levels don't go that high.
    Has your installation been done by a reseller, or yourself ?
    many reasons can cause that error
    - bad installation
    - wrong tool selected or defined incorrectly
    - wrong settings in the operation
    What skill level are you at with CAD and CAM systems ?
    May 2008
    10
    Chamfering Toolpath
    Quote Originally Posted by Superman View Post
    - bad installation
    Hi, superman
    any idea how to fix these problem, BTW my CAD & CAM skill level are acceptable, not that good but i think i can make a part from a drawing to final machining , I'm just trying MasterCam and see how it work.
    Mar 2006
    1013
    "I'm just trying MasterCam and see how it work."
    Bootlegger Alert!
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Sep 2008
    111
    Quote Originally Posted by Mike Mattera View Post
    Bootlegger Alert!
    Mike Mattera
    stole the words right out of my mouth.
    contact your reseller and try it the right (legal) way.
    May 2008
    10
    I just format the whole system and reinstall the program, yep! Superman you are right it just a bad instalation, now don't get the anoying warning anymore. Thank guy for your help.
  1. Mastercam neck pocket toolpath
    By jimmiethekid in forum Musical Instrument Design and Construction
    Last Post: 05-23-2010, 12:02 AM
  2. Export toolpath to mastercam
    By rdpdo in forum ArtCam Pro
    Last Post: 05-22-2010, 08:14 PM
  3. 4 axis mastercam toolpath
    By podgee in forum Canadian Club House
    Last Post: 05-06-2009, 05:08 PM
  4. HELP Mastercam X2 toolpath problem
    By cam168 in forum Mastercam
    Last Post: 01-16-2008, 07:59 AM
  5. 4th Axis Toolpath with mastercam
    By rcrabb in forum DIY CNC Router Table Machines
    Last Post: 01-07-2007, 03:41 AM
