Hi
Can You help setup my water cooled spindle 2.2kW.
I have got inverter
ABB ACS 100 ACS101-4K1-1 2.2kw 230v 1to3ph https://www.inverterdrive.com/group/...V/default.aspx
Spindle
1) Spec:φ80*205 mm (Diameter:80mm x Length:205mm)
2) Power: 2.2 KW
3) Voltage: 220V
4) Frequency: 100- 400 Hz
5) Current: 8.5 A
6) Speed: 8000-24000 R/min
7) Water Cooling
This inverer has 250Hz max. Can I connect this spindle with him? (lower speed)
RPM on inverter is only 3600 so How Can I get 24000RPM?
can you help me to setup parameters for this spindle on inverter.
Manual https://www.inverterdrive.com/file/A...l/default.aspx
Thanks Pawel
