been reading and re-reading alot of these posts, plus being doing a bunch of practice. Things are starting to come together! thanks everyone for the help.
i do have one new question though
tonight i was doing some 3/8" steel. 60amp tip. about 41ipm.
when doing a straight cut, the voltage is a perfect 141. I verified this by turning off THC, setting cut height and making a straight cut.
I then cut some profiles using the THC, and again things were great.
I then cut some small holes (about .4" diameter). and the torch wants to dive hard into the plate. I turned off THC and set cut height to .0625, the voltage that it reads is 151 or above. The hole looks good, but i'm just wondering why the voltage would be higher?
I then go back and do a straight cut, and its back to 141
I have the ground directly on the stock.
Any thoughts? I'm thinking about just cutting these holes without THC. is there a way to turn it off mid program?
