586,269 active members*
3,604 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > HDI remove the .5 x,y offset generated in Mach 3 when I upload code?
    Sep 2008
    43
    Yeah so when I upload my gcode it adds a half inch all the way around my part, I am using freemill to generate gcode and my offset was 0,0,0. Could this be happening in Mach 3? How do I fix it?
    I just started cutting foam taped to my table and my work table is only 8 x 14. Every half inch is gold.
    Nope.
    Could you explain a bit better what's happening? What size tool are you using?
    Oct 2006
    975
    Are you setting the Home position to match the zero location used in the toolpath?
    Wes
  1. Replies: 8
    Last Post: 12-15-2010, 09:32 PM
  2. Mach 3 work offset retention.
    By Geoff86 in forum Machines running Mach Software
    Last Post: 01-30-2010, 09:03 PM
  3. Mach BNE 51S - Fanuc 18-T - work zero offset???
    By BoKo in forum G-Code Programing
    Last Post: 07-27-2009, 01:42 PM
  4. Upload your video of you machine running with Mach
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 07-10-2007, 11:44 PM
