587,035 active members*
2,923 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > Employment Opportunity > (4) Small plastic parts needed. 3D print, Injection mold, machine?
Results 1 to 7 of 7
Hybrid View
    Feb 2010
    3447
    Talking (4) Small plastic parts needed. 3D print, Injection mold, machine?
    Each assembly has 2 pieces. I need 2 assemblies for a total count of 4 pieces.
    The picture attached was rendered in Solidworks 2010. The picture to the right of it was a 3D printing prototype done on a 3D printer-Maker Bot. The Maker bot prototype was simply a demo test to make sure the concept worked. The white piece to the left of the red printed assembly is 1 of 2 old supports, which the new red assemblies will replace.
    The piece needs to be accurate as possible. A rep-rap or mendal is not accurate enough. I need a commercial 3D printer to tackle this job, of maybe someone is tricky enough to make it on a mill? It must be ABS or a softer plastic equivalent. No metallic surfaces such as metals, etc.
    I figured i would see if anyone can tackle this.
    Thank you!
    (the entire assembly is in the ballpark range of 2"x2")
    Attached are both the solidworks part files, and assembly. If anyone would like a different file type please message me.
    Attached Thumbnails Attached Thumbnails ballscrew support render.JPG   IMAG0267.jpg
    Attached Files Attached Files
    Mar 2007
    13
    what is it with designers and square corners:withstupi
    Jun 2008
    562
    Take a look at these guys. I've used them in the past and was very satisfied. They also have online instant quotes for some versions of building.
    http://quickparts.com/
    Mike
    Feb 2010
    3447
    Quote Originally Posted by ultrapeter View Post
    I love square corners
    Feb 2010
    3447
    Closed. Job has been done. Thanks.
    15362
    diyengineer
    PM sent
    Mactec54
    Jun 2010
    i have a printer that might be able to do this. it is a sand printer that after printed i use a resin to harden the sand. does this sound like it may work for you? Email me at [email protected]
  1. INJECTION PLASTIC BENCHTOP MACHINE
    By Yorch1 in forum Benchtop Machines
    Last Post: 09-12-2011, 09:37 PM
  2. how much excess plastic needed around a mold.
    By JackCaper in forum Vacuum forming, Thermoforming etc
    Last Post: 09-01-2008, 05:05 AM
  3. Want to buy small injection machine
    By DANTAMPA in forum Want To Buy...Need help!
    Last Post: 01-10-2008, 02:55 AM
  4. Tool Maker/ injection mold builder needed!
    By MnotLyon in forum Employment Opportunity
    Last Post: 03-08-2007, 08:57 PM
  5. CNC driven plastic injection machine
    By aadams in forum Mechanical Calculations/Engineering Design
    Last Post: 03-14-2005, 04:17 PM
