Hello all;
Our Machine is Moriseiki FL-2 model 1998
Our main unit is fanuc 21-tb
I want to explain our problem
firstly machine gave servo alarm because of electric problem. Then we bought servo amplifier module from fanuc moscow. And also we controlled spindle amplifier module and power supply module in different moriseiki fl-2 machine and we saw that the spindle amplifier module and power supply module is also working fine...
So now we can say that our servo,spindle and power supply module is working fine... But when we power on our machine the machine doesn`t give alarm first. but if I want to use handle jog; i see that x and z axis doesn`t move. And also if I want to cw spindle; I see that spindle doesn`t turn properly... if I continue use handle jog; alarm 410 accured on the screen. And also if I continue cw spindle;alarm 750 accured on the screen...
Yesterday I disconnect x axis motor from X axis mill and I opened the machine again... And I saw that motor doesn`t turn with handle jog...
Anyone have an idea about my problem?
My Best Regards
Cuneyt Bircan
