586,546 active members*
3,147 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > EG&G TORQUE SYSTEMS PMDC servo & MOTRONICS PMDC motor Specs ???
Page 1 of 3 123
Results 1 to 20 of 59
    Feb 2008
    553
    Question EG&G TORQUE SYSTEMS PMDC servo & MOTRONICS PMDC motor Specs ???
    Hi to everyone,
    I've just bought two used PM DC motors for cheap,
    The first one is a "PM FIELD SERVO MOTOR" from "EG&G TORQUE SYSTEMS" Model NO: MH-2120-003J code: 0283. It also has a sticker with three codes like this: ASM:
    E.C:
    E.I.R:
    the codes were hand written.
    The second motor is a "MOTRONICS Corporation" PT.NO. 801679-001 REV.G CAT.NO. 31107-14-210-05 INS. CL. H VOLT 24 DATE CODE 0183. It's a PM DC motor.
    If you guys can help me with these:
    1) On motor #1(EG&G servo) I have no idea of the voltage, Amp & torque ratings...it's a pretty fast motor, supplied it from 6V to 12V to 24V It's fast at 12V & Very fast at 24V (the bearings are old & whistle a bit)
    2) On motor #2 (Motornics) I have no idea of the Amp & torque ratings.
    Any info is welcome .
    Thanks !
    cnc2.
    http://img405.imageshack.us/img405/2378/cimg4042y.jpg
    http://img444.imageshack.us/img444/6...mg4043r.th.jpg
    http://img137.imageshack.us/img137/5914/cimg4044.jpg
    http://img137.imageshack.us/img137/2098/cimg4045.jpg
    http://img152.imageshack.us/img152/549/cimg4046.jpg
    http://img152.imageshack.us/img152/3741/cimg4047q.jpg
    PS: I had troubles uploading the pics to the Zone, I had too many timeouts even when the file sizes were well below the limit, so, I used ImageShack.
    Dec 2003
    24223
    These EG&G were made by Cleveland Motor Control http://clevelandmotioncontrol.com/index.asp
    If you go to the DC motor link on the site you should see 2120 series.
    If not I have the original manuals.
    Al.
    Albert E.
    Feb 2008
    553
    Al.
    Many thanks Al
    From the website you pointed I've found this http://clevelandmotioncontrol.com/do...atform2100.pdf & this http://clevelandmotioncontrol.com/do...duct_Guide.pdf and also found an xls sheet http://clevelandmotioncontrol.com/do..._data/2120.xls
    On the sheet I've selected "motor winding type: H" because of the MH-2120-xxxx in the model NO. is that correct ? (the sheet said 1600rpm @45V for winding H but @24V it seemed to be spinning faster than that)
    I'm a bit conserned about the second motor, the fact that you don't know it might indicate that it ain't no good
    Can I change the servo's bearings by myself without the risk of demagnetizing it ? (& loose torque like a stepper)
    Thanks !
    cnc2.
    Dec 2003
    24223
    I have serviced quite a few without inserting a 'Keeper' but if you want to play it safe, slide a metal tube in place of the armature.
    Careful not to damage or chip the magnets.
    Al.
    Albert E.
    Feb 2008
    553
    Thanks for the info, I'll see if I can, I'd prefer to work it out safely.
    cnc2.
    Feb 2008
    553
    UP !
    I still have no info about the Motronics Corp pmdc motor & have no idea about the bearing it has on the mounting plate, no obvious indication about its previous life....all I know is that it's made in Little Falls NEW YORK 13365
    Thanks !
    cnc2.
    Dec 2003
    24223
    I would say the bearing on the mounting plate was due to the particular application it was used in. You should be able to just remove it?
    For sizing, you can get approximately by comparing physical size with CMC motor.
    For voltage, apply a known fixed low voltage DC and measure the rpm, if you estimate a max rpm for the motor to be 2500rpm as a safe guess, then pro rate the max voltage accordingly.
    Al.
    Albert E.
    Feb 2008
    553
    Thanks for the reply Al !
    I already know its rated voltage it's 24VDC (on the name plate) RPM is lower than the other motor & I think I'll be able to measure it with my bicycle's multifunction digital tachometer, but I have no idea about its rated current & torque. (by looking inside after removing a plastic plug from the frame I can see the winding which seems to be made out of thick wire near the gauge of phone copper wire)
    Any idea on how I can know the rated current & torque ? (holding the shaft with a towel I could slow it down but I couldn't stop it of course the reading on the amp meter went up to around 3A if I recall)
    Feeding it with 12V & low current I could stop the shaft, but when blocked the motor makes noise sounds like "ggrrrr grrrr grrrr"
    Is there a way to replace a broken brush holder ? it's the outside plastic thread which is broken on the EG&G servo.
    Thanks !
    cnc2.
    Sep 2010
    1765
    Re: EG&G TORQUE SYSTEMS PMDC servo & MOTRONICS PMDC motor Specs ???
    oops; thought I was on last post when I wrote this and then found out I was only on like post 10! if it was already answered, please excuse this post.
    Quote Originally Posted by cnc2 View Post
    Any idea on how I can know the rated current & torque ?cnc2.
    the big Motronics has a speed of around 1800 RPM (dancing between 1772 & 1800)
    So 24v/1.8krpm= 13.33 v/krpm=Kb.
    Kt is same number, just different units. In your units, Kb=11.81 * Kt where Kt=#-in/amp when Kb=v/krpm units.
    So your motor Kt=13.33/11.81 = 1.13 #-in/amp
    Kt is independent of voltage so when you put 12v on it and slowed it with rag and it pulled 3 amps, you squeezed with 3.4#-ft of torque.... sorta low.... you should be able to squeeze with 6-10#-ft if you put your heart and soul into it
    anyway, now you know how much torque your motor will put out, next to figure how many amps it can take.
    Easy: it can take upto that level of amps that cause it to overheat and melt down.
    So put the shaft in a vice to lock it from turning, use a small 0-12v say 5amp variable power supply and beginning at o amps turn it up to 1 amp and let it sit for 3 thermal time constants. don't know thermal time constant? find a similar physical size motor and yours will be very close. If this is a 3"dia x 5"L motor (I did not go back and look - too many pages), it has thermal TC of about 30 minutes. so put 1amp into it for an hour or so and watch temp on case. it will rise until it stops. case temp on these motors was about 90C max (200F). so to be safe, watch temp and go for say 120F. If not there with 1amp, then raise it to 1.5 or 2amp and wait another couple hours. Keep going up until you get to 120F at hottest spot on motor case and call THAT your motor's max continuous current rating. Its torque rating is then 1.13#-in times this amps.
    Feb 2008
    553
    Sorry for the late reply guys, and thanks for replying !
    Al,
    I already checked everything on my settings page, I even disabled and re-enabled receiving PMs...but same result, must have been banned...might be for asking a stuuupid question to the site owner, but who knows ?
    Mike,
    Your reply is just WOW ! Amazing & very informative, thank you so much !
    Thanks !
    cnc2.
    Feb 2008
    553
    Well, I did the test with the bike's speedometer which has an RPM function in it & it all went out OK.
    It wasn't very accurate but gave a good rough figure because I was holding the sensor in my hand trying to hold the required distance from the magnet (3mm +-1mm).
    The test results:
    the moderate EG&G which looked/sounded very fast, has a speed of around 3600 RPM (the speedometer is rated 3600 RPM max & I saw speeds of 3720 RPM)
    All the tests were made with the motors standing vertically on the table.
    Thanks for all the help !
    cnc2.
    Nov 2010
    Motronics DC Motor
    I used to work in the engineering department of Motronics and may have a catalog burried in my files. I will take a look and get back to you.
    Feb 2008
    553
    Quote Originally Posted by sbe7922 View Post
    Hi sbe7922,
    Hat's off to the engineers ! this motor is older than me & seems to be in perfect condition, can you tell me on what kind of machinery it was used (for what kind of machinery it was made) ? & what's the purpose of that bearing on the side of the motor's mounting plate ?
    Is it suitable to be used as a servo motor ?
    When I spin the motor's shaft back & forth with my hand, I hear TICTIC as the direction reverts, is it a sign of failing bearings or just the brushes which are a little loose in their cages & move from side to side ? the motor is quiet while running.
    Thanks !
    cnc2.
    Sep 2010
    1765
    if SBE, ex Motronics, doesn't find an old data sheet on it, post physical size and voltage/speed you got no load again in 1 single post. from that, various of us will be able to compare it to similar rated motors we design, build, sell, service, and be able to make close guess what its current, continuous torque, and max speed ratings are for you.
    Feb 2008
    553
    Quote Originally Posted by mike_Kilroy View Post
    Hi mike_Kilroy,
    Look at this pic, it's the motor on the right side of the pic:
    It's a PMDC NEMA 34 size motor, voltage is 24 VDC but it has no current rating marked on it...its shaft is round & smooth with no key or flat surfaces, the end of the shaft is conical.
    This motor seems to be quite powerful, I did try to stop it by holding the shaft with a thick piece of cloth it barely slowed down with little rise on the amp meter, I don't think it reached 3A, I couldn't stop it & the end of the shaft got hot from the friction with the cloth.
    I couldn't measure the speed under load.
    you'll find more pics in the first post.
    Thanks !
    cnc2.
    Sep 2010
    1765
    nice heavy duty looking motor.
    the ticking may be result of its previous life maybe running in 1 direction all the time; that would seat the brushes in a way that if you run backwards they will click across the commutator bars. I would not be worried about the sound.
    Answer these questions and I will give you a best guess of what your motor is rated:
    - diameter?
    - full length?
    - rpm at some voltage?
    OK, ur tach checker thing cannot measure speed. do it a different way then. is 24v on it too fast to count rotations of shaft in a given time like 10 seconds? then use jumper cables and put it on your car battery at 12v - can you count revs in given time now? still to fast? put a 1.5v D cell across it surely you can count revs in a given time now!!?? the longer the time the more accurate the result so see if u can count revs for 60 seconds. if possible give us the revs/time for multiple voltages if you want morre accurate motor specs; say 1 d cell, 2 d cells (3v), maybe a 5v power supply, etc. With multiple readings we can solve V=IR+Kb*N and get u better ratings!
    Feb 2008
    553
    Will it disappear if I replace the brushes ?
    - diameter?
    - full length?
    Well, motor's diameter is ~78mm length is ~124mm from plate to plate (these measurements were took using a plastic ruler but it should be accurate enough)
    The mounting plate size is NEMA 34.
    Why do you say that my "tach checker thing cannot measure speed" ? I used the RPM function which measures the wheel's RPM by counting every pass of the magnet by the sensor.
    A quick test at 2.5V using a 1000mA power adapter, revealed that the motor is very slow and ticks & turns at a non constant speed, and voltage drops down to ~1V ~1.3V
    At 3V the motor spins at a constant speed without ticking & the voltage drops down to ~2.5V ~2.6V sorry, i could not count the RPM accurately, it looks like it is between 1 & 2 rev per second....the bike's tachometer shows ~166 ~177 RPM ~3.1V becomes fluctuating between 3V & 3.1V
    Edit: when I find more time I'll try to do some testing with my battery charger which has 6V, 12V & 24V at 10A & 5A
    Thanks !
    cnc2.
    Dec 2003
    24223
    Here is an older link that may help determine torque etc.
    http://www.cnczone.com/forums/diy-cn...o_experts.html
    One way of determining the torque on the shaft in B is with a pulley and a spring scale tied to a cord around the pulley, the torque can be determined from the known dia. of the pulley.
    Al.
    Albert E.
    Feb 2008
    553
    Thanks for the replies guys !
    Thanks for the link Al, I don't have a spring scale yet, but i have a torque wrench & will try to use it to measure the motor's torque, it'll be a bit tricky to find a way to couple the wrench to the shaft.
    Mike, your approximation is interesting, but I'll try to do more accurate testing later, just to be sure/confident. I always thought I could stall 0.5 Nm by hand ....One thing bothers me a bit in your aproximation: a while back I've been told that 1Nm of torque requires a motor of around 100W of power. But when I do the calculation backwards using your numbers I find that the motor has three times more torque than you've found ???
    If we take U*I=P, we end up with 24*8.5= 204W of input power, with an efficiency of 0.82, we have 204*0.82= 167.28W of output power which is equivalent to approx 1.6 Nm of torque. ???
    A while back in a mailing with a Leroy Somer tchnician about an old motor they made, he found in their archive that the motor was rated [email protected], but he couldn't tell me weather it was the continuous or peak rating, I asked him about the heating ...etc & he told me that I have no way of testing it outside of a lab environement because the varnish on the winding might burn before the motor's case gets too & ruine the motor.
    Maybe your testing technique is for testing the temperature to prevent demagnetisation. but what about the wingdings ?
    PS: don't be pissed off, I might be totally wrong, I'm no E engineer & have no experience with electric motors...etc. I've just read a lot of Al's posts & discussed with that Leroy Somer guy about one of their old motors, I was going to aquire from a scrap yard, it was a bit pricey & had no rating on it exept date code & part number because they made it for Honeywell bull.
    Thanks !
    cnc2.
    EDIT: I forgot to mention, I'll be using UHU servo drives on the three axes.
    Sep 2010
    1765
    where is my reply from yesterday 4pm? cnc2, I sent another long reply but is not here! took me about 20 minutes to compile (:
    bottom line was
    1) I'm by no means p'ed! but happy u r digging in on this! -
    2) I also showed ur rule of thumb is dependent on rpm so using it I got motor rating closer to 1nm
    3) my .5nm was based on looking at similar motor sizes and their cont rating (a rule of thumb is similar size motors have similar continuous torque ratings; torque rating is determined by mass and size. speed, peak torque, amps, volts are all engineered and can be almost anything in a given size motor.
    4) this cont torque rating is that: continuous - what the motor can put out forever w/o overheating, NOT max or peak torque. so if you apply correct volts and current to this motor rated .5 or .75 or 1nm, it will put out a peak torque - probably around 5nm! that is why u cannot stop it by hand!
    5) DO run the motor on 12v car battery and get your bike tach reading; I calced based on numbers down in the mud at 3v... do 12v and we will have a good speed to work with! remember, this test will let us calculate current rating and max speed rating of the motor, not cont torque rating; that is determined by physical size only. two different 'tests' to get your full motor data.
    there; this summary reply took only 5 minutes! If you want to see the 1nm 100 rule thing I can post calcs showing that later.
Page 1 of 3 123
  1. PMDC servo Motor -JAM
    By leo83 in forum Servo Motors / Drives
    Last Post: 08-31-2012, 02:18 PM
  2. PMDC motor, what makes one none reversable?
    By LUCKY13 in forum CNC Machine Related Electronics
    Last Post: 10-17-2011, 08:04 PM
  3. Electrocraft PMDC servo ID ? Plz !
    By Schweinhund227 in forum DIY CNC Router Table Machines
    Last Post: 12-01-2009, 08:34 PM
  4. PMDC Motor Control, MC-60M
    By PKMan in forum CNC Machine Related Electronics
    Last Post: 01-09-2009, 11:10 PM
  5. Looking for a source for PMDC servo motors
    By bgolash in forum Servo Motors / Drives
    Last Post: 01-31-2006, 10:26 PM
