586,453 active members*
2,794 visitors online*
Thread: STL Stock
Results 1 to 7 of 7
    Feb 2004
    466
    STL Stock
    Have you been successful with using stl model for stock?
    I have been trying to but I cant seems to get the stock on the model I am trying to mill.
    I have tried several ways, first I modeled my stock model and made 3d milling on it in Solidcam and saved updated stock, also I have tried to save the model as STL file and it seems that I can never get it right. See the pictures, the origin is shifted, I thought I could model the "stock model" using different ways as to manipulate the origin to land here and there but still cant get it.
    Any thoughts?
    Oct 2004
    48
    Hi there
    If I am correct, you are trying to use the saved solid simulation STL file as the CAM stock model for a new CAM part which is no doubt a subsequent operation to the same part.
    This can be done easily!
    There are two ways to save the STL file, one is from inside the solid verify window and one is from the Feature Tree. Both work fine except one saves the STL with the origin the same as MAC 1 POS 1 (saving from Solid verify), the other method saves with the origin the same as the cam part design model main origin.
    I use the "save from feature tree" to keep the design model origin and I make sure that on my next CAM part that is to use this STL file that I use mates to move and fix the origin so it is in the same place relative to the part to be machined as it was in the 1st set-up/Cam part. Once you do this, you can select the STL file saved from the 1st part/operation and you should have it automaticly placed exactly where you want it (0,0,0 with the design model)
    I hope this makes sense and works for you.
    Jake
    Oct 2007
    499
    Hey, that's interesting that you can save the STL stock from the Job Tree in CAM Manager. I didn't know that.
    I have been using the save from SolidVerify method and then using a lovely little program called "CtrlView" to manipulate the STL so that it aligns with the DesignPart. I have found that when you are defining the stock with an STL file it pays to check the position with the "Show on Model" button before accepting. I do this and if the stock isn't in the right place I tweak the transforms in CtrlView, save it to the STL file targeted in SolidCAM then do the "Show on Model" thing again.
    Normally for our parts the DesignPart origin is outside of the model by some considerable distance, so I shall certainly try the Job Tree method, but will still have to manipulate the STL file for reorientation.
    Feb 2004
    466
    Thanks for the explanation Jake I will try that.
    Bob could you explain what you do in CtrlView? I have downloaded the trial v3.30 and don't really know what to do.
    Jake I tried saving from "solid verify", I ran the simulation then right clicked on the model and there were 3 options: stock (greyed), view and properties. This particular stock machining uses two coordinate systems, I guess it should be ok. I am going it right?
    Oct 2007
    499
    Konstantin,
    In control view I change the orientation & position of the STL model so it aligns with the part when I define the STL as the Stock.
    To do this in CtrlView, click on "View" then "Select all objects". Once you have selected all the objects it a matter of clicking "Edit" and then "Transform selected objects". This opens up a dialog which enables you to move and rotate the STL object to your desired position. I have found it best to apply the settings in the Transform dialog and do a "Save as" without coming out. That way your transforms aren't cleared and you can re-manipulate with reference to your starting point.
    Good luck
    Bob
    Feb 2004
    466
    Finally some success.
    I did as you instructed Bob and I only manipulated the values of "Shift" property in "Transform" window namely dY and dX and then saved as STL binary. Saving just STL would result in a stock being very big and sort of deformed.
    Oct 2004
    48
    Hi Konstantin
    To save STL stock file from the solid simulation screen, see screen shot below.
Name:	stl scrren 1.jpg
    To save from feature tree, see next screen shot.
Name:	stl scrren 2.jpg
    If your cam part has multiple coordinate systems it doesn't mater as the STL file is only a representation of the job after the machining operations.
  1. 7/12 stock to cnc
    By LeeWay in forum Vertical Mill, Lathe Project Log
    Last Post: 11-15-2012, 10:52 PM
  2. no stock
    By GRD MACHINIST in forum FeatureCAM CAD/CAM
    Last Post: 07-19-2009, 05:22 AM
  3. CNC gun stock router help
    By chris l in forum CNC Wood Router Project Log
    Last Post: 02-18-2008, 04:54 AM
  4. Flipping the stock
    By mrscheider in forum MetalWork Discussion
    Last Post: 01-30-2008, 06:47 PM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
