586,119 active members*
3,367 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Running 440V VFD with 380V
    Apr 2006
    3498
    I have 380Volts Power Supply, My VFD is PUMA brand 2KW and have mentioned 440Volts input power.. Can i run this VFD with 380Volts input..
    The Motor i want to run is 380Volt 3-phase 2.2HP...
    As its chinese made so i can't get the support services.. I have the manual available..I need your suggestion in this regard..
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    24221
    I cannot see any problem, the 3 phase out should be compatible with your motor and any low level logic voltage for the control circuitry is usually dropped off the high voltage so I would not expect that to be affected.
    Al.
    Apr 2006
    3498
    Al.
    Hi AL, thanks for the reply... So you mean that i can input 380V to VFD instead of its rated 440V.. As my motor is 380V so i think it will output 380Volts to me..
    Regards
    24221
    If you already have them you should not have any problem testing to make sure, I cannot see it being that critical.
    Al.
    Apr 2006
    3498
    Thanks Al, from last week i am studying the manual provided with the VFD.. . The VFD can be controlled with 380V...It has lot of setting parameters.. Should i have to do all the settings?..Or their are some specific parameters that i must set and leave the rest..
    It has Vector sensorless control too.. Is it good to use this option.. VFD is able to get all the information from the connected motor...
    24221
    You normally have to set the motor parameters, pole#, voltage etc, as a minimum, if it has auto tune then this would be done next to capture the motor characteristics.
    Sensor less Vector is generally better than V/Hz variable speed mode.
    Al.
  1. X2 running
    By krymis in forum Benchtop Machines
    Last Post: 11-10-2009, 07:28 PM
  2. switching a 440v lathe to 220v
    By dannystooblue in forum Phase Converters
    Last Post: 01-28-2008, 07:24 PM
  3. 5AX 500 anyone running one?
    By BJ-DEKA in forum Bridgeport / Hardinge Mills
    Last Post: 12-27-2007, 05:10 PM
  4. Running hot, really, really hot
    By imagineer in forum Stepper Motors / Drives
    Last Post: 01-18-2007, 03:51 PM
  5. bp heidenhain 440v to 220v
    By CASTLEVILLE in forum Bridgeport / Hardinge Mills
    Last Post: 12-06-2006, 11:40 PM
