586,329 active members*
5,282 visitors online*
    Dec 2008
    Isolate 0-10V? (Sinumerik 802C retrofit)
    Hello!,
    I'm retrofitting a TOS CNC mill with a Siemens Sinumerik 802C.
    The original Heidenhain TNC 145 shortcircuited because a cabinet lamp had worn thorugh a flatcable in the DC reg. for the axis. (Simoreg 6RB2025)
    Should I isolate the 0-10V, analog setpoint, signals between the 802C and the Simoregs?
    The 802C can deliver 3mA on the 0-10V outputs, I haven't figured out the input impedance for the Simoreg 6RB2025 / 6RA2620 yet.
    I've been looking at Phoenix Contacts 3-way isolator, but they have around a 3mS delay on a 10-90% rising edge (if I'm not wrong) and are quite expensive (DIN rail mounted)
    If anyone has a schematic to a mill that uses the 802C and wants to share it I'd be happy to look at some examples!
    Thanks!
    //Jocke
    24221
    Most drives that use analogue ±10vdc have op amp input so the impedance is high and should not present a problem.
    Of all the different systems I have implemented and mixed and matched over the years I have never had a reason to isolate the ±10vdc analogue signal.
    Al.
    Dec 2008
    Ok!, then I won't isolate the ±10VDC signal!
    I suppose you don't want to build in unnecessary delays in the system, and like you said, the Simoreg drives have op amp inputs, (6RB2025 have 10kΩ input impedance)
    Thanks!
  1. retrofitting with sinumerik 802c
    By is_razi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-17-2020, 09:34 AM
  2. Siemens (sinumerik 802C base line)
    By Afzal in forum Controller & Computer Solutions
    Last Post: 01-16-2013, 02:36 PM
  3. Ideas to isolate workpiece from waste material
    By RiceCustomRich in forum Rhino 3D
    Last Post: 08-22-2009, 08:01 AM
  4. Siemens 802C
    By Htech in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2009, 11:57 PM
  5. Optical isolate Xylotex issure
    By monte55 in forum Xylotex
    Last Post: 10-25-2006, 04:43 PM
