Originally Posted by
cnc_swe
I translated the error "wireless communication". I meant RS232 (V24 serial.)
You need a simple terminal program like Windows HyperTerminal or any application where you can put your parameters for RS232 transmission.
The last software should be in the PC to fill up the text file you get from me to be in Sinumerik.
All data bits I got in the previous example, you must login on the Sinumerik first and write some communikation data.
ex: 5012 = 0000 0000 Whether you must manually write or download via RS232.
First of all you must enter the MACHINE DATA BITS in Sinumerik.
Next, find the menu in Sinumerik as I/O On this menu you will find Transmitt or recive file.
If both of the terminal have same data ex: RST, 7, 1200 baud, Non, 2stop the communikation can start between computer and Sinumerik.
You may enter any parameters manually, but there are several hundred.
Try to read your manual how to edit this database.
Trying to get data from another machine instead of from a PC based on the same idea but then you will be able to manage the RS232 also in the machine.
I can send the owner's manual in English if you want.
