My TC tapping head just came in yesterday and I've been doing a little reading trying to figure out how to use it. I see there's a math to the timing and was curious if anyone here made a list with speeds, feeds, etc. (if not lets make one
My first hole I need to tap is a blind hole in 6061 aluminum at .25" depth. I've bought a bottom spiral tap as recommended and if anyone here can take a look at the math to make sure it's correct.
Using a #36 drill (diameter of .01065) and a 6-32 bottom spiral tap.
6-32 - at 200 rpms @ 64 IPM
Math
32 tpi (.32) x 200 rpms = 64 IPM ?
Now I understand the PCNC 1100 Z axis maxes out at 65 IPM, so I'm limited to smaller tapping sizes.
Tormachs Example -
1/4 - 20 tap - 500 rpms @ 25 IPM
(Tapping with TC head for 1/4 - 20)
G0Z1 - (Rapid motion to plane z=1)
X0Y0 - (Rapid motion to hole center location)
Z.150 - (Rapid motion to plane z=.150)
M3s400M8 - (Spindle on CW, 400 rpm, Coolant On
g4 p4 - (Dwell for 4 seconds)
g1z-.9 f25 - (Feed tap to z= -.9 and 25 ipm)
m4s400 - (Spindle on CCW, 400 rpm)
g4 p0.5 - (Dwell for 0.5 seconds
g1 z.150 - (Retract tap to z=.150)
