587,030 active members*
3,715 visitors online*
    Jan 2010
    4
    EZ-Trak DX II Start-up issues
    HELP! Our Ez-Trak is hanging on start-up. Truly all of a sudden.
    We've been having intermittent issues with the screen going blank. More of a nuisance than anything. Restart the machine and usually you're good to go for the rest of the day.
    Last week the screen went dark, I restarted and here's what happens:
    The BIOS loads, and that's it.
    The screen lists the BIOS info and "128KB Cache Memory" and hangs.
    Normally the HIMEM test is next (I think) but not anymore.
    Changed out the weak CMOS battery, no change.
    Put in a DOS start-up disk, plugged in a keyboard I can see the C: drive and all it's files.
    I do have the original floppy for a format and reload, but want to do that as a last resort thinking it's something else.
    ANY ideas?
    Al
    EDIT: I pulled up the exe files, saw eztrak.exe and ran it.
    BMDC counts down, the display shows up, and I get a runtime error.
    Jul 2010
    Is your C drive an actual hard drive, one of those DOMs, or a ISA Flash-card?
    When you replaced the CMOS battery, did you re-input the correct settings for your C drive?
    Jan 2010
    4
    Got it!
    I had to reinstall the software to the on-board hard drive.
    From what I gather, we had a boot sector issue with the drive.
    FYI:
    I swapped out the battery AFTER the issue presented itself as that seems to be the root cause of all things bad according to what I've read here.
    I guess I did it fast enough that all the settings were still there. I wrote EVERYTHING down before starting, and it was ALL there when done!
    Back up and running, and the boss is off my back, as of course, "I broke it".
  1. EZ Trak homing issues
    By Fusioncraft in forum Bridgeport / Hardinge Mills
    Last Post: 12-05-2011, 02:20 PM
  2. 4896 issues... where to start... (Long)?
    By Dave's_Not_Here in forum Techno CNC
    Last Post: 06-11-2010, 01:36 AM
  3. EZ-Trak start-up error
    By jfm in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2009, 03:53 PM
  4. Replies: 4
    Last Post: 01-06-2009, 05:20 PM
  5. Single start vs double start ballscrew.
    By darik in forum Linear and Rotary Motion
    Last Post: 03-22-2007, 01:53 AM
