586,263 active members*
3,799 visitors online*
    Oct 2005
    1237
    Question Light house flashing circuit
    My neighbor brought over his garden light house and asked me to fix it. He then asked if I could make the light do a "real" light house flsh with dim to bright flash, then to dim and out, repeat. After researching a LOT, I found this circuit.
    http://www.discovercircuits.com/PDF-...OUSEFLASH5.pdf
    My problem is, I can't find a LMC6442 op amp. Low voltage, low power. Punching in the data at Mouser got no hits and no substitutions. Any ideas?
    Also I'd like to power this circuit with a single AA nicad recharged by the solar cell. I saw a link here for a voltage increasing single AA battery holder with a 5v output. I lost that link. Does anyone have a link to something similar?
    Feb 2010
    230
    http://www.jameco.com/webapp/wcs/sto...eeText=LMC6442
    This link will sell you an op amp that you are looking for.
    Don't know about the 1.5V to 5V or the solar, happy hunting for those.
    Regards.
    Regards, Carl
    Jan 2010
    2141
    AA battery holder with step up to 5 volts:
    http://www.sparkfun.com/commerce/pro...oducts_id=8248
    Description from SparkFun:
    5V DC to DC Step Up - 1xAA
    sku: PRT-08248
    Description: The is a wonderfully simple 5V power source from Bodhilabs. This unit uses a single AA battery and generates 5V using a DC to DC step up circuit. A jumper is provided on the unit to disconnect power and includes a terminated (right is red) connector. Perfect for all those 5V applications that need to be small, and run on less than 100mA.
    Specifications:
    •Voltage regulation: +5V +/-3%
    •Typical current: 100mA or less.
    •Typical ripple: 150mV peak-peak (*) @ 135kHz
    Oct 2005
    1237
    THANKS! it took a long time to find that circuit. Tons of On/Off circuits, but this is the only dim to flash bright, them dimming circuit out there that I could find.
    Jan 2006
    738
    Great circuit...
    About the only way I could think of to reduce your current draw would be to use an ultra low power microcontroller to drive a FET with PWM for dimming.
    Steve
  1. Flashing
    By hjl4 in forum Viper Servo drives
    Last Post: 07-08-2010, 04:50 AM
  2. KURAKI KV-1000 FLASHING RED LIGHT
    By Scottjit in forum Fanuc
    Last Post: 11-19-2009, 07:05 PM
  3. Replies: 6
    Last Post: 10-26-2008, 12:16 AM
  4. Flashing bit
    By mr_electrician in forum Fanuc
    Last Post: 02-15-2008, 08:19 PM
  5. Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal
    By SCG11762 in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2007, 02:08 PM
