586,685 active members*
2,378 visitors online*
    Jun 2007
    26
    Spindle will not start
    Yesterday I used the machine and it worked fine.
    Still - I needed to turn on/off the spindle in the spooler by clicking the spindle on off button.
    This morning - I cannot get the spindle to start at all.
    Is there any way I can get some help?
    I got the spindle to start - by changing "controller type" I am using type 2 controller.
    Still - even though the configuration area, has the spindle auto start and auto stop checked ---- the spindle does not stop automatically.
    Feb 2007
    966
    Yes your controller type should have been REV-2. If not then the spindle won't start. What was it set to ?
    Does the spindle start when you click the spindle start butt on the screen or just not start from a file ?
    Larry K
    Jun 2007
    26
    With Larry's help the spindle start/stop problem has been solved and is no longer a problem
    Jan 2006
    179
    Re: Spindle will not start
    Quote Originally Posted by Arcticfox46 View Post
    I am having the same issue with my machine. What did you do to resolve it?
    Feb 2007
    966
    Maybe contact Larken ?
  1. Spindle Won't Reach Speed after Brake On while Spindle Start
    By mflux_gamblej in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2014, 04:59 AM
  2. Replies: 1
    Last Post: 05-03-2013, 12:42 AM
  3. spindle start-up
    By poster in forum Milltronics
    Last Post: 08-30-2011, 12:34 PM
  4. Spindle will not start!
    By cmdr_keen in forum Tormach Personal CNC Mill
    Last Post: 08-12-2009, 11:52 AM
  5. Spindle won't start!
    By gamila in forum Fadal
    Last Post: 04-08-2008, 05:07 PM
