586,465 active members*
3,844 visitors online*
IndustryArena Forum > CAM Software > Mastercam > IF I HAVE A OLDER VERSION SAY MASTER CAM 9
Results 1 to 10 of 10
    Apr 2008
    23
    AND SOMEONE SNDS ME A FILE THEY DID ON X2 HOW DO I OPEN IT ???
    Sep 2006
    48
    You can't. The formats are different.
    You can have them save it in something like a .dxf or a .dwg and open that just fine however.
    Stu
    Apr 2008
    49
    Tell them to save the file as Version9 (.mc9).
    X3 can save the file as older version, not sure about X2 though.
    Nov 2015
    Re: IF I HAVE A OLDER VERSION SAY MASTER CAM 9
    https://en.industryarena.com/forum/s...d.php?t=194554
    **SOLVED**
    So I am using x9 and I wanted to save as (mcx) and it said it wasn't able to. So then I save it in the following method.
    File>Save As>*All Files* (drop down menu)
    Then name your file whatever you want and end it with (.mcx-4, mcx-3, mcx-2)
    Then locate the file and right click it to rename it and change the mcx-4 to (.mcx).
    Ok so when you save it as (.mcx or another version older than what you're using) Mastercam detects you trying to save it as an older file so it gives you an error message but since (.mcx-4,mcx-3,mxc-2) don't exist, it doesn't detect anything.
    x, x²,x³,x⁴--(.mcx)
    x5-above --(.mcx-5,mcx-6 and so on)
    So there is no such thing as (mcx-4, mcx-3, mcx-2)
    If you want it to open in 32-bit or 64-bit you'll have to rename the file in the computer you're using..
    It saves tool paths too!
    I don't know why Mastercam isn't able to do this
    It should give us that option.
    It's scheme to make us buy the newer versions
    Hope it helps all y'all
    Sent from my SM-G386T using Tapatalk
    Nov 2015
    Quote Originally Posted by bobrob View Post
    **SOLVED**
    x, x²,x³,x⁴--(.mcx)
    Hope it helps all y'all!
    Quote Originally Posted by stucaruk View Post
    Stu
    Mar 2017
    I'm using Mastercam 2017 and tried this - following your instructions completely - can't open the file in Mastercam X5 or X9. Does anyone else have this problem?
    Apr 2003
    3578
    Beacuse you can't as the file and path are not compatible. it does not work. if it were that easy then CNC software would of done it. Also the GUI and more hase changed over the versions that make them incompatible.
    Cadcam
    You can't. Try exporting to IGS. You won't be able to import toolpaths unless you save them as geometry on the newer version. But all the newer versions should be able to save files with MC9 extension. I doubt that the operations will come into an older version though. The older version just don't have the same toolpath options.
    Apr 2003
    3578
    You can save for example a X3 Mastercam file and open with everything to X9 to 2018. but you cannot save a X3 and open in it in Mastercam V9.1 being prior to the X series. You can get Geo in most cases back. but you have to look at what the geo is. for sxample if you have a solid model you cannot save it using IGES. but if you convert the solid to surfaces then you can. but if I have a Solid model I would save as a Step or Parasolid. BUT when you to go to options and save to an older versions of Step or Parasolid as those formats just like the software's have grown. Another reason to upgrade you software.
    There really rhymes to the resins on how these things work.
    Hope this helps.
    Cadcam
    Apr 2003
    3578
    Oh man I forgot. you cannot bring newer file back into older ones with any paths. never have been able to do that.
    Cadcam
  1. Replies: 5
    Last Post: 06-26-2014, 12:02 PM
  2. Master cam version 9.1
    By gbarron in forum Mastercam
    Last Post: 09-06-2012, 06:44 PM
  3. Edgecam older Version
    By CNCRim in forum EdgeCam
    Last Post: 09-26-2006, 06:46 PM
  4. Pete needs older, RH7.2 version of emc
    By pgruendema in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2005, 11:46 PM
  5. Older version g320 with long leads
    By kiepie in forum Gecko Drives
    Last Post: 11-01-2005, 09:03 PM
