587,011 active members*
3,743 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Want to control your spindle with Mach3 but can't.. Maybe this helps.
Page 23 of 23 13212223
Results 441 to 443 of 443
  1. #441
    15362
    Re: Want to control your spindle with Mach3 but can't.. Maybe this helps.
    Just 2 year to late to help these guys but may help for someone in the future
    Mactec54
  2. #442
    Jan 2014
    17
    Can this newer version be run using PWM input?
    Update: i got an email answer on the above question. No, it doesnt have the capability of PWM input. But, the C11g BOB has an integral PWM to 0-10v analog output.
    Can it be toggled back and forth between panel control and 0-10 analog control without punching in codes in the panel?
  3. #443
    Jan 2014
    17
    Quote Originally Posted by ken226 View Post
    I've received and installed this new version. Apparently' to answer my own question, theres no quick way to toggle between panel control and mach 3 0-10v analog control.
    I hav'nt made any chips with it yet as i just finished fabricating the mount and wiring it up yesterday.
    Using panel control, it responds immediately to my hand pressure on the spindle. I can feel it add torque and maintains the same speed.
    When under mach3 analog 0-10v control, hand pressure reduced the speed by about 75rpm.
    I damaged my c3 pulse cards sensor while fabricating the bracket, so am running the 0-10v control completely open-loop.
    On my next day off i'll test run it and take a few videos in panel mode, and in analog 0-10v mode using open-loop mach3 control.
    Once the c3 sensor arrives, ill try a similar test in closed-loop mode and see how much, if any, the PID loop helps.
  1. Getting C11/Mach3 to control 2.2kw Spindle
    By kostas1 in forum Mach Software (ArtSoft software)
    Last Post: 12-10-2013, 03:53 PM
  2. helps with overheating of spindle motor..
    By victorcnc in forum Servo Motors / Drives
    Last Post: 03-08-2011, 06:55 AM
  3. MEI LC/DSP Prof. Motion Control. Wo helps me on: Software and drivers?
    By Harmpy35 in forum CNC Machine Related Electronics
    Last Post: 08-07-2010, 09:59 PM
  4. mach3 spindle control on nm-200
    By urbanimports02 in forum Novakon
    Last Post: 01-19-2010, 04:33 PM
  5. VSD-A Spindle control in MACH3?
    By mkuivamaki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2008, 08:09 PM
