Hi All
I've been reading quite a lot and I'm impressed with the support and advice given on this forum, well done.
I have however, struggled to find what is the best laser cutter for my needs, so I'm hoping someone can make some suggestions.
I wish to be able to cut puzzles out of high grade (AKA dense) birch plywood. the majority of plywood will be 6mm thick, but I am hoping to make some raised puzzles using 9/10mm plywood. I need at least 300 x 400mm laser bed, but am looking at slightly larger for increased productivity - no higher than 900mm though
I'd love to be able to afford a laser with the synrad laser, but unfortunatly my budget doesn't reach that far. Instead, I'm looking at eithe r buying from a couple of Australian companies that distribute the chinese models. (Rapid Concept or Red Dot Machinery), or purchasing from wklaser.
1. What laser cutter would best suit cutting plywood, while leaving a smooth thin cut line between the puzzle peices?
2.Am I better going with a 60W for a smaller line or an 80W (or higher) for more power (I understand the cut line becomes bigger the higher the wattage?)
3.If higher power means wider cut line, is there anything you can do to make the cut line smaller? (i.e. different lenses to make the beam smaller?)
4.What options in a laser should I be looking for?
I am quite technically minded when it comes to high tech equipment, as I used to be an analytical chemist and instrument maintainer, but for UV and Infra Red lab based equipement....laser cutters is a whole new ball game for me.
Thanks in advance for any help!!
