587,006 active members*
2,963 visitors online*
    Jul 2010
    Converting Fanuc G code to Seimens 840D G code
    Can some one help in how to convert the Fanuc G code programs to be compatible with Seimens 840D. Is there a way or I have to write the whole program again.
    Aug 2010
    Try Putting a G291
    Jun 2009
    8
    Hi
    If your fanuc programs use I,J & K's on the radius call out this will run in siemens, the biggest problem is the cycles. in fanuc you have cycle G83 in siemens you have CYCLE83(). If you program is just plain G-Code without to many cycles you should be in good shape. I use the cimco text editor to search and replace when converting a program, this speeds things up considerably.
    mark
  1. Help Converting Image to g-code
    By buddym in forum Uncategorised CAM Discussion
    Last Post: 09-24-2013, 08:56 AM
  2. Replies: 4
    Last Post: 03-29-2011, 02:39 PM
  3. Help with Siemens 840D code.
    By bb_24_1 in forum Community Club House
    Last Post: 04-09-2009, 09:24 PM
  4. converting biesse code
    By sidskilly in forum CNC Machining Centers
    Last Post: 05-19-2008, 07:43 PM
  5. need help with converting corel to g code
    By pfcary1 in forum Commercial CNC Wood Routers
    Last Post: 01-07-2007, 02:09 PM
