586,460 active members*
3,101 visitors online*
Page 76 of 76 2666747576
Results 1,501 to 1,506 of 1506
  1. #1501
    Re: Mach3 2010 Screen set
    He actually sent me the link. Thanks for the help jim
  2. #1502
    Quote Originally Posted by Sniger7700 View Post
    Hi sir
    Did you try the 2010 software ? I’m running the same
    Board as you was in the time your posted in here.
    Best regards
    Kasper
    Hi Kasper
    I never tried it because I didnt get enough onfor aboit it. I see your Question is dated to 2022. Did you try with your one ???
  3. #1503
    Quote Originally Posted by Eveb View Post
    Hello,
    This Mach 2010 looks pretty good.
    Do it works with chinese xhc mk4 ethernet board?
    Regards
    From what I hear from my customers, the XHC boards are one of the worst when it comes to running macros. I've had some have a bit of success using the Chinese macros on my website, but others haven't been able to get it to work at all.
    If you want to use the 2010 screenset, I'd only recommend an ESS or a CNC Drive controller.
  4. #1504
    Nov 2013
    4411
    all development on Mach3 ceased eight years ago, as far as I'm concerned its obsolete.
    Mach4 is the replacement and is light years ahead, and is still and actively being developed. It won't work with crappy Chinese made motion boards.
    Craig
  5. #1505
    Hi i just bought the screenset too.
    I now realised that it might not be available anymore ?
    Is this project still active.
    I'll try to send an email to him.
  6. #1506
    May 2005
    Quote Originally Posted by Jamesbond2285 View Post
    Hi, I just bought and installed the screenset, and I'm having troubles with the auto tool zero script. My probe plate is 29mm tall (I don't have the exact number in front of me at the moment unfortunately) and when I enter that number, it changes it to -29.00. When a measure is executed, after the second, slower probe, it jams my tool into the plate. It looks like the highest + value I'm allowed to enter is +.999 for some reason. I'm using a puck mounted in place to my bed.
    It works perfectly for me on an old CNC machine that has an LPT port, but now I bought a small new one with a BL-UsbMach-V22 USB controller and I have the same problem
  7. #1507
    Sep 2005
    1195
    "a BL-UsbMach-V22 USB controller and I have the same problem"
    you can not slave axis ?
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
