586,446 active members*
3,531 visitors online*
Page 51 of 76 41495051525361
Results 1,001 to 1,020 of 1506
  1. #1001
    May 2003
    96
    Re: Mach3 2010 Screen set
    Hi Ger, I have tried out what you suggested but to no avail, however I understood what was happening and realized (and apologize) that I have misled you. I open mach 3 through the KeyGrabber in which I have a joystick configured to function with mach3. As can be seen on the attached photo, the problem (I think) is with re-assigning of the relative buttons to the new OEM buttons designated in the "Jog" tab control of 2010 screen set (as described in Mach3 macro program manual - http://www.machsupport.com/wp-conten...o_Prog_Ref.pdf ). I have no idea how I could identify their translation code so as to refer to it in the KeyGrabber, is there a way to know this?
    Marting
    Martin G
  2. #1002
    Quote Originally Posted by sngatlanta View Post
    I never had those vs won't I have to completely re-setup Mach 3 if I do that?
    No, you should be able to just install the other version riht over the existing version, and nothing should change. Just in case, make a backup copy of your .xml first. That contains all of your settings.
  3. #1003
    Quote Originally Posted by marting View Post
    So your sending shortcut keys from your joystick through Keygrabber. The issue is probably that the 2010 Screenset doesn't use the default shortcut keys. You'd probably need to modify the screenset to change the hotkeys.
    Can you tell me exactly what each button is supposed to be doing, or what buttons it's pressing in the default screenset? Be aware that a lot of buttons in the default screenset are not even available in the 2010 Screenset.
    You said fine positioning. Can you explain exactly the process you use?
  4. #1004
    Jan 2008
    48
    Just looked for an older download and didn't see one at newfangled site. Any suggestion where to get one?
    "Man who say it cannot be done should not interrupt man doing it."
  5. #1005
    The Artsoft FTP site, in the Mach folder I think.
    ftp://anonymous:[email protected]/
  6. #1006
    Jan 2008
    48
    Well its working and a big thanks for the help.
    I was running this machine for 2 years without Mach 3 spindle control until just a few weeks ago and thought that was an improvement but combined with this screenset and the auto tool routine I'm elated.
    Thanks again and I look forward now to getting your jointcam routine/program.
    Maybe I wont wait 2 years.
  7. #1007
    So the older version fixed it?
  8. #1008
    Jan 2008
    48
    I think so. I may reload the 066 back just to test but I need to get some work out of
    the way first.
  9. #1009
    Hi Gary,
    I ordered your screenset earlier today. Can't wait to be organized and centered! Could you please check if my order went thru.
    Ab
  10. #1010
    Feb 2009
    1290
    First thing I did after upgrading the computers running my routers was to email Gerry, he replied right away. Great service and thanks for the help!
    Thank You.
  11. #1011
    Quote Originally Posted by asilverio View Post
    Hi Gary,
    Ab
    I replied to your email with the screenset files about 7 hours ago. Check your spam filter.
  12. #1012
    Hi Gary,
    I have checked. I did not get any email. Could you please resend. thx
  13. #1013
    I just replied to your email, and also sent a copy from my gmail account.
  14. #1014
    Hi Gerry,
    I do reference all home
    Then move the y and x to where I want and make it home.
    Put the probe there and choose initial probe or simple and does the same thing. Goes down and touches and goes all the way to my -7 with soft limits or without it hits the home limits and goes down a little and does not come down far enough to touch again. Then either goes all the way down and crashes with probe or goes up and hits home.
    When I calculate probe height and the clearance amount and compare to what the system says the work surface should be it does not reach the work surface.
    I have attached screenshots.
    The park does work. It goes where it should.
    m6 locates the fixed plate and will do the entire process sometimes but when it goes on top of the part it is too high and again did not calculate the z correct.
    Could you please help
  15. #1015
    I replied to you via gmail. Sorry for the delay, it's a holiday weekend and I was traveling today.
  16. #1016
    Aug 2005
    114
    I have the 2010 Screenset.
    Problem is the pop-up screens don't pop up when I click them.
    It isn't until I hit the 'alt' (or is it the windows key?) that they do show.
    Guessing they are there, just behind my main screen.
    Did I do something wrong at install? How to fix?
  17. #1017
    What "pop up screens" are you referring to?
  18. #1018
    Aug 2005
    114
    The tabs at the top. They pop up different windows.
    At least on my mach3.
    See attached picture.
  19. #1019
    That's the default screenset, and is not part of the 2010 Screenset??? Those buttons have nothing to do with the 2010 Screenset.
    Did you load the 2010 Screenset?
  20. #1020
    Aug 2005
    114
    Ger21,
    Yes, My 2010 screen is loaded on my machine out in the shop at home. I don't connect it to the internet. But the computer is plugged in.
    Please forgive me, that was just a quick screenshot grab of mach3 off the interweb to visually show what I was talking about. I have failed at that miserably and now attached a random 2010. So, yes, definitely referring to the 2010 screen.
    When I drop down a menu and click my selection for example drop down the 'CONFIG' menu and select the 'Motor Tuning'. <---- When I do this the small seperate 'motor tuning and setup' window doesn't appear to open. For any selection. I did not experience it with original Mach3 sceen.
    I'm running Mach3 with latest update on Win 7 Pro with 2010 Screenset. What appears to be happening is the window is opening, but remaining behind my 2010 main window. Appears to do same in windowed or fullscreen. Could perhaps be related to my Windows 7 configuration because I run as a minimalist with all windows animations etc turned off.
    Any ideas on this would be greatly appreciated. Otherwise it is useable as is.
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
