I am still trying to get to grips with Solidworks, slowly getting there!
One small problem is really bugging me at the moment.
If I have two parts in an assembly and use a reference hole on one part to 'drill' a hole in the other part, when I save the assembly the hole is missing in the part because I created it in the assembly.
I have attached a simple test assembly showing the problem.
If you load the assembly all the holes appear correctly.
If I load part bracket A it does not have the two holes in it that I created in the assembly.
Is there an easy way to get Solidworks to save the holes into the actual part?
Andy
