I have a 14" wood working band saw that runs at 3,000 sfpm ...
I've read mixed reviews on whether these saws can be used for cutting aluminum and brass, without gearing them down.
Given that a bi-metal blade for it would run ~$34 I thought I might give it a try.
Any thoughts?
I have found three blade choices..
1/2" wide 14-18 variable tooth, .025" kerf
1/2" wide 6-10 variable tooth, .025" kerf
3/4" wide 10-14 variable tooth, .035" kerf
Any recommendations?
Any suggestions for rigging up wipers to keep the aluminum chips from imbedding into the rubber faced wheels?
Would I be better off getting one of these?
[ame="http://www.amazon.com/Watt-Portable-BandSaw-Metal-Cutting/dp/B000UJODAE/ref=sr_1_6?ie=UTF8&s=hi&qid=1277999882&sr=1-6"]http://www.amazon.com/Watt-Portable-BandSaw-Metal-Cutting/dp/B000UJODAE/ref=sr_1_6?ie=UTF8&s=hi&qid=1277999882&sr=1-6[/ame]
I've been watching Craig's List but haven't seen on of the 4" x 6" horizontals listed... and their running ~$250 new.
