586,356 active members*
2,960 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G540 .xml / Mach3 / gcode error issue
    Sep 2009
    90
    Aloha All,
    I'm getting close with my X2 hoss conversion. I have the G540 and Mach3. I am generating gcode with vectric cut2d. I have made a simple circular pocket in a rectangular piece of stock. When I load the gcode with the 540B
    .xml I get the error message "Radius to end of arc differs from radius to startline ###". Also, if get no graphic toolpath in the toolpath display.
    When I load the mach3mill profile and load this gcode, it loads fine and there is a toolpath graphic. The only variable that I can isolate between what works and what doesen't is which .xml profile I load with the mach3loader at mach3 startup.
    I was hoping that this is an error message that someone has seen before and there might be a simple fix or tweak. Any thoughts?
    Is there a different place that I might post this question?
    I can attach or email the gcode .txt if anyone is interested.
    Thanks! -4ist
    Mar 2009
    1114
    Very common, go Config Menu/General Config and then change your IJ Mode to the opposite selection. If it is in Incremental change it to Absolute, or vise verse.
    It all depends on how your CAM software puts out radius commands.
    ~Scott
    Sep 2009
    90
    That's it!!!
    Thanks Scott!
    That did it. I guess I should learn to compare ALL the differences between settings when I have isolated the problem. Scratch one stupid question...
    -4ist
    Mar 2009
    1114
    Not a problem
    ~Scott
  1. G540 E-stop and Mach3
    By Astroguy in forum Gecko Drives
    Last Post: 02-03-2012, 05:10 AM
  2. gcode error problems
    By dek in forum RFQ Feedback
    Last Post: 03-13-2010, 05:37 PM
  3. Calibration or gcode error?
    By Lappy in forum Mach Software (ArtSoft software)
    Last Post: 10-04-2009, 12:08 PM
  4. Mach 3 GCode Error
    By stabbs in forum Mach Software (ArtSoft software)
    Last Post: 08-21-2009, 07:02 PM
  5. Mach 3 issue - possbily arc gcode related
    By fseger in forum Mach Software (ArtSoft software)
    Last Post: 05-28-2008, 11:35 PM
