I have a Fryer VB-40 with an Anilam 1400m control that refuses to process any spindle orientation or speed commands. Whenever I try to manually induce a tool change through an M6 command I get an "ERROR: PROG. CONTROLLER ERROR OR TIMEOUT IN SPINDLE SEQUENCE!" message. This machine is equiped with a Baldor (catolog# ZD18H207-E) AC Vector controller. Could this AC motor controller be programmed wrong, or would this problem arise form within the CNC control itself?
