586,296 active members*
4,201 visitors online*
    Feb 2010
    Mori MV35/Fanuc 6M
    I can type programs manually, etc. I cannot get my RS232 port to recognize input from my laptop. Does anyone have the parameters so I can double check mine. I think the original owner locked out some things to make the machine tamper proof.
    Please help?
    2932
    What happens when you punch out from the machine to the PC?
    What happens when you try to send from the PC to the Machine?
    Aug 2008
    53
    RS232 parameters
    Here is a link to a guy I know who used to work for Fanuc.
    It is the parameters that are needed for communication.
    He is a great guy that does drive rebuilds.
    http://www.kfasllc.com/rs232_6.htm
    Feb 2010
    Computer
    Thanks for the replies.
    I can't send a program from my laptop to the CNC via the 232 port. The CNC keeps scrambling the code. Manual input and operation is fine. I've tried different baud rates, etc.
    Steve
    2932
    What program are you using to send programs to the CNC? What are the settings in the program you are using to send?
    24221
    See pdf if it helps.
    Al.
    Attached Files Attached Files
  1. Help Please, Mori MV 35 w/ Fanuc 6M B
    By SteveY in forum Fanuc
    Last Post: 03-01-2010, 05:54 PM
  2. Help Mori MV 35, Fanuc 6M B
    By SteveY in forum Mori Seiki Mills
    Last Post: 03-01-2010, 05:52 PM
  3. Mori M300A Fanuc 10m
    By cncmori in forum Mori Seiki Mills
    Last Post: 12-28-2009, 05:19 PM
  4. Mori SL-3, Fanuc 11T Schematics
    By Trutech in forum Mori Seiki Mills
    Last Post: 08-18-2008, 08:02 PM
  5. spindle belts for mori seiki mv35/40
    By brandou10l in forum Uncategorised MetalWorking Machines
    Last Post: 01-06-2008, 12:59 PM
