587,006 active members*
3,014 visitors online*
    Nov 2005
    80
    Foam cutter Kit
    I'm interested in cutting foam I was searching for some foam cutter kit having size around 30-40" x 15-20" x 15-20".
    The frame (no electronics, if accepts nema 23 steppers it will be great) should cost below 1000$.
    Anyone know such kits ?
    May 2011
    Feb 2008
    51
    Quote Originally Posted by RedLabel View Post
    I never fiddled with a kit, most of them I don't like. I done better on drawer slides and all thread.
    This being a prime example of what not to avoid. You have to see it try to work as delivered.
    FoamLinx small hot wire cnc foam cutters
    You are far better off building your own unit, I am writing my second book on foam cutter design.
    My first unit cost $700 with steppers and controller. The first picture is one side. The other side is the mirror image.
    As you can see by the second picture I have gone on to build better units.
  1. CNC foam cutter
    By vcatalasan in forum CNC Wire Foam Cutter Machines
    Last Post: 01-06-2024, 07:29 AM
  2. Hot Pin Foam Cutter
    By damae in forum CNC Wire Foam Cutter Machines
    Last Post: 01-25-2009, 02:40 AM
  3. True 3D foam cutter
    By max_imum2000 in forum CNC Wire Foam Cutter Machines
    Last Post: 01-05-2007, 02:18 PM
  4. My first CNC! soon to be foam cutter
    By nikolatesla20 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-06-2005, 07:48 PM
  5. Foam cutter
    By paulried in forum CNC Wire Foam Cutter Machines
    Last Post: 10-30-2003, 10:58 PM
