The more I read, the more confused I get! Is it ok to run 24v into a 1.8volt motor? Is there a % of maximum volts you can run into a motor for its volt rating. I have 4x (1.8v 3a) and 4x (24v 4.4a) stepper motors. Both lots 6 wire. How many volts should I put into the motors to run a small hobby mill. Im running a "4xcnc10b" driver which handles 10 amps per phase per motor. (dtllc.com). Also, is it a general assertion that the amp rating on a motor is per phase? Any help would be much apreciated! :wee:
