586,389 active members*
3,091 visitors online*
IndustryArena Forum > Community Club House > Trying to find a step-type timing pulley:
    Aug 2009
    22
    I'm looking for a combined unit for a step timing pulley. I have thought of a ton of different ideas and need your input.
    Here is a picture of something i'm looking for. Basically have the Larger Pulley mated to the smaller drive pulley in any fashion (doesn't have to be machined out of a single piece of metal)
    Oct 2006
    975
    If you have 2 pulleys with the same shaft diameters in the center it would be easy to drill 2 holes for dowel pins and then 2 more hole at 90º to the dowel holes to be drilled and tapped for a small screw(10-32UNF etc.) to bolt the pulleys together.
    Wes
    24223
    Is there any real need to mate them together?
    Especially if the shaft is keyed, I usually use a set screw through to the key.
    Al.
    Aug 2009
    22
    Al.
    I want to mate them together for simplicity sakes for my rack and pinion. i want a nice clean setup and think that would be the best bet.
  1. What is a timing belt and pulley ?
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 02-18-2011, 01:38 PM
  2. L Timing pulley hob?
    By DennisCNC in forum MetalWork Discussion
    Last Post: 08-30-2009, 09:45 PM
  3. Can't find a timing pulley
    By chevdrgtrk in forum Uncategorised MetalWorking Machines
    Last Post: 07-31-2007, 06:15 PM
  4. can I get a 13 tooth timing pulley
    By unterhaus in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2006, 05:11 PM
  5. Calculating the right timing pulley
    By cnc2k in forum MetalWork Discussion
    Last Post: 09-01-2005, 01:18 PM
