587,012 active members*
3,482 visitors online*
Results 1 to 14 of 14
    May 2008
    667
    My futur Wood and metal Shop (Pics)
    Hi, just would like to share with others the construction of my dedicated woodworking shop and since I'm a 25 years experience as a CNC machinist, my metal working shop.
    This is a 24 X 36 shop.
    This will be for my lathe, My 6X4 Aluminum CNC router and a futur CNC mill and all my woodworking equipments.
    Concrete will be poor this week, walls and trusses are due within 2 weeks.
    Hope the pictures will upload, had some problems with them.
    Will keep updating as soon as work progress.
    Jeff
    Attached Thumbnails Attached Thumbnails PICT0140-1.gif   PICT0142-1.gif   PICT0151-1.gif   PICT0154-1.gif
    May 2008
    667
    Just an update
    Attached Thumbnails Attached Thumbnails PICT0214-1.gif   PICT0218-1.gif   PICT0223-1.gif   PICT0229-1.gif
    Nov 2004
    436
    You should cinder-block up the walls to about 40 inches, and then use a 2x8 sub-plate to cover the tops. This will give you 11'6" ceilings. Way better for woodworking (swinging large boards around) and dust collection systems, and lighting.
    Or not. I did, and I am way happy with it
    May 2008
    667
    Hi, thanks for your comment.
    This is easier and a lot cheaper for me to order 10 feet walls.
    Walls and trusses are already ordered for a 10 feet high ceiling.
    Should be here in a couple of weeks.
    Jeff
    Aug 2004
    2849
    Why didn't you pour a footing?
    Paul
    May 2008
    667
    pouring a real footing would have cost a lot more.
    The concrete slab is 5 inches thick and 12 inches thick for the first 2 feet around it so this is some kind of a footing.
    The concrete slab alone cost $5000.00 and concrete alone cost more than $3000.00.
    Plus the wire mesh, steel rod, thermo foild, 4 truck load of gravel, excavation, compacting, polishing.
    I need to keep money for the building, 24 X 36 is the dimension on a house so this is a lot of money, this is at least a $20000.00 to $25000.00 construction.
    Jeff
    Nov 2004
    436
    They call that a turn-down footing here in clarksville. Unlike the criminals that poured my slab, it would appear that your contractors know what they are doing.
    Excellent pics! Look forward to seeing the rest.
    May 2008
    667
    Could I ask why you call them Criminals
    Thanks for yours comments.
    Jeff
    Jan 2006
    628
    That's going to be a great shop. I'm jealous.
    So here's a dumb question. Aren't winters going to be an issue without a footing that extends below the frost line? In the north east US (where I am), I believe it's 3-4' minimum.
    I can imagine that the slab would float just fine, but won't the exterior walls be prone to movement without a deep footing? Or maybe you're some place where that isn't an issue...
    Steve
    Nov 2004
    436
    Well, in some places, the American work ethic is slacking, greed is more important that taking pride in your work, etc. Ha ha... I said some...
    I paid 3500 for my slab, to get 75% of what I was promised, and with amateur quality. 2 years later, I have cracks that extend from wall to wall. I found a shady mason to do my block work, too. Needless to say, the drain-tile, positioned around the base of the walls (slab is 2 feet underground at the back), was sealed at both ends with clay. I recently put in a sump pump (just in case), and let the water out of that drain tile by elaborating on the drainage system. Sorry if I sound bitter, but my faith in contractors is shot right now. I get better results doing things myself... even if it is my first time.
    Are you speaking of the frost line? I never knew that floating had anything to do with that. Would you mind elaborating?
    Rob
    Jan 2006
    628
    Yes, sorry about the typo - meant frost line. I don't know if that's relevant for outbuildings, garages, etc. Could just be residential.
    Steve
    Nov 2004
    436
    I always thought it was a matter of keeping the ground beneath the slab from freezing/expanding. If the bottom of the concrete is below the frost line, mission accomplished. Would not mind knowing for sure, though.
    Rob
    May 2008
    667
    First of all, there's a thermofoild underneath the slab, this help a lot preventing frost to get under it and shop will be kept warm, this also prevent frost.
    Good soil is very important, will also place draining all around the slab, so
    that way, less water will go under the slab.
    If I had to build it with a footing, The rules where I live are at least 5 feet deep, this would have cost at least $10000.00 and not sure about cracking anyway
    Jeff
    Jan 2006
    628
    Sure, that makes sense. With good drainage there shouldn't be pooling of water under the slab and with a heated shop you may not get a deep freeze either.
    I've seen garages with badly cracked/heaved slabs, but they were unheated and the drainage is uncertain or nonexistant. Could also be thin, unreinforced cement - so it's hard to say what the real issue is.
    Just trying to learn something. Thanks.
    Steve
  1. Wood or metal
    By cncman2 in forum DIY CNC Router Table Machines
    Last Post: 08-04-2013, 04:29 AM
  2. My futur Wood and metal Shop (Pics)
    By jeffrey001 in forum Canadian Club House
    Last Post: 05-28-2010, 12:45 PM
  3. Comments Needed-Wood vs. Metal in Garage shop
    By hsgreer in forum DIY CNC Router Table Machines
    Last Post: 03-15-2008, 07:07 PM
  4. Pics of my metal cnc table (base w/rails complete)
    By guru_florida in forum DIY CNC Router Table Machines
    Last Post: 12-14-2007, 12:12 PM
