586,685 active members*
2,755 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Current setting for TB6560 3-axis board (eBay)
    May 2010
    I just have my 3-axis board from eBay ( ) in hand. The chipset is TB6560. I will be using this board for my mini cnc router. Lowest current setting for this board is 1.5A (using dip switches).
    Unfortunately my steppers are 1A and I have to set it in the board. The board shipped with 0.22 ohm registor (red-red-silver-gold), which you can see from the image. It has a DIP switch for current setting but I think I need to replace the registors for having lower current setting (1A).
    Somebody having knowledge on this board please advice.
    By the way, I also attached the config doc, which I received from the seller.
    Thank you in advance.
    Attached Files Attached Files
    Jun 2008
    467
    Post
    Leaveme,
    .5 ohm resistor for 1 amp output.
    JoeyB
    A doughnut a day keeps the doctor away.
    May 2010
    Hi JoeyB,
    Thank you for yor help.
    Do you mind to share the calculation...I mean the way you calculated it.
    Also appreciate your opinion about the dip switch setting.
    Dip settings are like this:
    current - sw1-sw2
    100%----on---on
    75%-----on---off
    50%-----off---on
    25%-----off---off
    I suppose my setting will be 50% for .5 ohm. Am I right?
    regards
    Jan 2011
    8
    tb6560 Current Setting
    According to the TB6560 spec sheet the current at 100% is 0.5/Resitance. For 0.22 resistors this is .5/.22 = 2.27 amps.
    Jun 2011
    Sorry lost the info... machine crashed
    Nov 2012
    I'm sorry for digging this old thread but I have a similar question.
    I bought this driver (TB6560AHQ -> 1.5-3A 3.5A Peak ... I'm still saving money to buy 3 geckodrivers) to drive three Nema 23 stepers wired as Bipolar series. They require 2.1A but the closest setting that I have is 75% which outputs 2.25A.
    Will it hurt the steppers if I set the current to 75%? If I can't, what should be the resistor value to output the 2.1A that I need?
    Thanks!
  1. need help with tb6560 board
    By terryt in forum CNC Machine Related Electronics
    Last Post: 12-15-2012, 09:18 PM
  2. need help with 3 AXIS (TB6560) CNC DRIVER BOARD
    By Jason Miller in forum CNC Machine Related Electronics
    Last Post: 08-11-2012, 03:34 AM
  3. eBay TB6560 Stepper Motor Driver Boards
    By Mad Professor in forum Stepper Motors / Drives
    Last Post: 07-03-2012, 04:38 PM
  4. TB6560 3-axis driver from ebay
    By kish89 in forum Stepper Motors / Drives
    Last Post: 07-01-2011, 01:10 AM
  5. ebay 3-axis TB6560 curiosity
    By techguyav in forum DIY CNC Router Table Machines
    Last Post: 10-24-2010, 10:28 AM
