586,419 active members*
3,138 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > proper name sheet metal stamping machine?
    Jun 2005
    141
    Question proper name sheet metal stamping machine?
    ok this may be a strange question but for "OLDER" machines and I have been told I like antiques but for single stage (one piece at a time hand loaded) stamping of light sheet metal .020-.080 what is the Proper or politically correct name for these machines and what where some of the manufacturers that made these in the 1920's and 1930's ?
    finding the "antique" your looking for is not always easy but it helps if you have proper name and some of the company's who produced that type machine so any info would be appreciated
    24223
    Punch Press maybe?
    Al.
    Oct 2006
    975
    Quote Originally Posted by Goldhunter_2 View Post
    You may find some information using some of the brands of those early punch presses. I was fortunate to be a die setter in a large water heater plant and here are some of the manufactures names I can think of:
    Bliss
    Johnson
    Cincinnati
    Verson
    Niagra
    I can't remember the mfg. name of the huge 600ton presses we had.
    Maybe the few names I listed will help some.
    Wes
    Jun 2005
    141
    thanks I'll try those
  1. nx-sheet metal
    By sk96_me45 in forum UG NX
    Last Post: 04-30-2010, 05:58 AM
  2. Complete sheet metal/machine shop in Yakima WA.
    By dub in forum Employment Opportunity
    Last Post: 02-17-2010, 04:17 PM
  3. Is there a such cnc machine that will bend sheet metal any way you want?
    By slashmaster in forum Uncategorised MetalWorking Machines
    Last Post: 03-23-2009, 11:44 AM
  4. Metal roof forming stamping?
    By DennisCNC in forum Bending, Forging, Extrusion...
    Last Post: 06-28-2008, 03:49 PM
  5. CNC operator – Sheet metal
    By scotia in forum Employment Opportunity
    Last Post: 06-11-2008, 11:46 AM
