586,974 active members*
2,953 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > canned cycle cannot perform positive value ??
Results 1 to 9 of 9
    Apr 2008
    123
    I did this part in Edgecam V9.5 and everything works except 1 line in the nc file.
    On line 'N2051' my Hurco says
    'CANNOT PERFORM A CANNED CYCLE WITH A POSITIVE VALUE'
    Can anyone shed some light on why this has happened?
    Edgecam showed everything ok and simulated machining perfectly.
    attached is a txt file of the NC code .
    Need to start producing this part monday am...
    Thanks for any help people. :-)
    Attached Files Attached Files
    Jul 2007
    378
    Hello
    N2046 M25
    N2047 T1 M06
    N2048 S2000 M3 M8
    N2049 G0 X-12.59 Y49.22 M8
    N2050 Z5.0
    N2051 G98 G81 Z-3.0 R2.0 F200.0 H01
    N2052 G90
    N2053 X0.0 Y-50.8
    N2054 G80
    This is not the format that I run on the VMX that I'm familiar with. The Format That I use goes something Like This:
    M25 Home Z-axis
    T1 M06 Change Tools
    S2000 M3 Spindle on
    G90 G0 X-12.59 Y49.22 M8 Position Table in X,Y, Coolant On
    Z30.0 Brings Tool 30.0 above Part
    Z1.0 Brings Tool 1.0 above Part
    G81 X-12.59 Y49.22 Z4.0 F200.0 Spot Drill 4.0 down from start (or -3.0 from Z0)
    G80 Z30.0 Canned Cycle cancle, Tool 30.0 above part
    X0.0 Y-50.8 Position table
    Z1.0 Brings Tool 1.0 above part
    G81 X0.0 Y-50.8 Z4.0 F200.0 Spot Drill again
    G80 Z30.0 Canned cycle cancel, Z 30.0 above part
    M9 Coolant off
    M25 Home Z axis
    T34 M06 Tool change
    I believe Hurco's use "Basic NC" code for their G code Side. Which basically means that their Canned cycles are Incremental movements on Z unlike the Standard Fanuc Format. Also, All Z values are positive but the Drill still goes in the negative direction. So it get a bit clumsy to work with. Let's try it again with a Peck Drill cycle
    M25 Home Z-axis
    T2 M06 Change Tools
    S2000 M3 Spindle on
    G83 X-12.59 Y49.22 Z21. Z4.0 F200.0 Peck Drill 21.0 down from start (or -20.0 from Z0) with a Peck of 4.0 (Second Z is the Peck amount)
    G80 Z30.0 Canned Cycle cancel, Tool 30.0 above part
    G83 X0.0 Y-50.8 Z21. Z4.0 F200.0 Peck Drill drill again
    M9 Coolant off
    M25 Home Z axis
    T34 M06 Tool change
    I believe Hurco's do have the OPTION to run Industry Standard NC (ISNC) so it would be Fanuc compatible. But It's an OPTION and it must be installed on YOUR machine to use it.
    Hope this helps
    glovbox20
    Apr 2008
    123
    Smile
    Thanks SO MUCH 'glovebox20'
    As you can prob tell I'm still learning NC code and things like canned cycles cause me porblems and the errors are difficult to see.
    Edgcam has so far been good to me but I will be happier when I'm more conversant with the codes.
    Thanks again for your help, you have made my monday a lot easier now.
    Respect
    xray34
    992
    Don't rely too much on CAD/CAM unless you know or very riable post processor.
    The best way to learn is trial error.
    Apr 2008
    123
    Good point 'CNCRim'...
    This is why I'm trying to learn NC programming as quick as I can
    and with all the knowledge on this forum I'm sure
    I will learn fairly quickly.
    Thanks man.
    Respect :-)
    Quote Originally Posted by CNCRim View Post
    Apr 2008
    123
    The part was made this morning and your code fix for me worked perfectly.
    Its something I will now always remember..
    Thanks again 'glovebox20'
    xray34
    Jul 2007
    378
    Happy to help.
    Just don't be afraid to correct me if I'm wrong.
    glovebox20
    Jan 2007
    203
    Quote Originally Posted by glovebox20 View Post
    Happy to help.
    glovebox20
    You are wrong
    All comments made are my opinion!
    Jan 2007
    203
    HA HA just kidding that info helped me as well
  1. Canned Cycle Help
    By vanbry in forum Okuma
    Last Post: 12-15-2009, 12:48 AM
  2. Canned cycle
    By tsaladyga in forum Post Processors for MC
    Last Post: 08-30-2009, 12:31 AM
  3. Canned OD cycle?
    By VWbmx in forum Haas Mills
    Last Post: 06-05-2009, 06:17 PM
  4. G76 Canned cycle
    By Stebedeff in forum Fanuc
    Last Post: 02-07-2008, 06:42 PM
  5. Canned drilling cycle on 0TB
    By guhl in forum Fanuc
    Last Post: 11-22-2007, 01:33 PM
