586,596 active members*
3,235 visitors online*
    May 2010
    Post CAD/CAM software for CNC machines
    Drawing / cutting software for a CNC machine
    Designed using NET 2.0 with C# and MS Access and Open GL for high standard graphics
    An application developed in Microsoft .NET by Cygnet Infotech, provides an easy to use interface for a metal sheet cutting machine operator. The program facilitates drawing shapes, importing new shapes to the library and optimizes cutting to reduce wastage. The system generated GCode for CNC machines with minimal implementation training.
    Benefits:
    The system is a one-stop solution for the customers to make 2D shapes and nest the same.
    [email protected]
    May 2010
    The most effective feature of this CNC Machine software is that, it was designed keeping in mind the clients who wanted a cost effective solution with user friendly features. This software has the facility to import shapes from other software making it more comfortable for first time users to transfer data.
    Check more of its features here - http://www.cygnet-infotech.com/CNC-M...-Software.html
    May 2010
    New blog post for CNC machine software
    Hello Everybody,
    Check out a detailed post on our blog for this software here - http://cygnet-infotech.blogspot.com/...-designed.html
    Please contact us to know more...We will be happy to assist you..!
  1. easy cut machines and software
    By pipelathe in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-10-2009, 07:38 PM
  2. Software for Light Machines
    By crackerkorean in forum Benchtop Machines
    Last Post: 02-28-2009, 04:22 AM
  3. Suggest software/machines for making tyre mould
    By Janardhan in forum Moldmaking
    Last Post: 12-07-2007, 01:34 PM
  4. Software for Joe's Machines?
    By TCGliderguy in forum Joes CNC Model 2006
    Last Post: 11-08-2007, 01:32 AM
  5. cncGraF V1.32 Freeware, CNC machines control software in DOS systems
    By cncGraF in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-12-2006, 08:53 AM
