586,493 active members*
1,963 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > spindle index, encoder, home/limit switch
Results 1 to 11 of 11
    May 2005
    35
    I have a few questions/comments about this circuit.
    http://www.dakeng.com/spindle_ckt.jpg
    LM339 is a Quad circuit and only one circuit is used?
    14-Dip comparator (differential/offset)
    why not use one of those single circuit TO-5 little metal cans or even an dual circuit 8-Dip (LM393)
    would not a high seed one be better?
    7404 has 6 circuits and only one circuit is used?
    What is it?
    Gate?
    PIC?
    cnc4pc.com's Index Pulse Card uses a HD74LS04 which has 6 circuits and only uses one circuit
    http://www.wrathall.com/Interests/CN...le_encoder.htm
    http://www.wrathall.com/Interests/CN...der_layout.pdf
    This looks much simpler;
    http://groupyahoo.com/group/turbocnc...ndexSensor.zip schematic.jpg
    This look better yet, it's all ready built
    http://www.wrathall.com/Interests/CN...ion/GP1A05.pdf
    The local Radio Shack don't have most of these pieces.
    The have the infrared diode/emitter, don't have the detector.
    So I'm looking at buying the pieces from Digi-Key, Jameco, Mouser, Newark InOne, ...... and replacing the LED and detector with a slotted unit.
    Something like cnc4pc.com's Index Pulse Card (ECG3100) OR ajaxcnc.com's Z-axis Optical Limit Switch
    Then again with a reflective flag and a reflective sensor I could make something like industrialhobbies.com's optical limit switch.
    Are usec. and nsec. the same or is ns much faster than us?
    Wile searching the net I found a circuit that uses a LM358. One electrician said it would be faster than the LM339 but it would cost more. The 358 is an amp not a comparator.
    Also, I've found out that this will also work as a switch.
    Wouldn't this do the same thing?
    http://robotics.me.jhu.edu/~llw/cour.../lab_02_09.pdf
    or this
    http://www.electronics-lab.com/projects/misc/017/
    I guess I'll just have to buy some pieces and run a few tests.
    Bill
    24223
    1nsec = 1000µsec
    If you just need to use the slotted switch detector, I don't know why you would need a comparator?
    What do you need super high speed for?
    Al.
    May 2005
    35
    why is the comparator used in the circuit if it's not needed?
    May 2005
    35
    according to this;
    http://www.ee.washington.edu/circuit...CIISCHEMIR_007
    all that is needed is the slotted opto switch and two resistors.
    24223
    Thats what I would have thought.
    Al.
    May 2005
    35
    if I'm reading this correctly; the comparator is in there for "noise immunity" OR "faster switching speeds"
    OPTEK's Application Circuits for the Phototransistor Switch
    http://www.optekinc.com/pdf/App%20Note%20213.pdf
    Bill
    24223
    The comparator essentially selects a level at which the turn on point is detected, If for instance you wanted to select turn on at a detected level of light, or sensitivity.
    Most operations use the either on or off due to the differences in characteristics in opto isolators.
    I have found they are not very good at linear amplification, unless you use something like the H11F1 which has a linear resisitive output.
    Al.
    Aug 2004
    2849
    Look at the outputs with and without the comparator and you'll see the difference....the comparator squares up the signal.....conditions it....
    24223
    For squaring, I would tend to use a schmitt trigger, the comparator is usefull if you want to set a certain threshold level.
    Al.
    May 2005
    35
    That's what I was seeing, makes it ON or OFF not somewhere in-between.
    I should take a class at the local Vo-Tech.
    7404 is a NOT gate
    http://www.kpsec.freeuk.com/gates.htm
    "A NOT gate is also called an inverter."
    http://www.boondog.com/tutorials/irled/ir.html
    "The 74LS14 is a Schmitt triggered hex inverter."
    I've also found out that a comparator is one of the many applications of an Operational Amplifier (op-amp).
    http://encyclopedia.lockergnome.com/...onal_amplifier
    I just snagged 100 Optek OPB875P55 switches off eBay for $6.25, that will give me a few to play with.
    Bill
    May 2005
    35
    Schmitt Trigger
    I finally cut my first cnc chips last Saturday.
    Now I must get my spindle index circuit together with what I have.
    So, with my LM358 Op Amp and another resistor I'll have my Schmitt trigger.
    http://www.radio-electronics.com/inf...tt_trigger.php
    http://hyperphysics.phy-astr.gsu.edu...c/schmitt.html
    http://www.swarthmore.edu/NatSci/ech...b2(OpAmp).html
    http://webpages.ursinus.edu/lriley/r...its/node5.html
  1. Sherline spindle to 30k RPM -- am I crazy?
    By nicad in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2010, 09:57 PM
  2. encoder issues
    By rutexus in forum Servo Drives
    Last Post: 05-22-2006, 12:49 AM
  3. Gilman box spindle pics
    By Swede in forum Benchtop Machines
    Last Post: 03-30-2005, 04:41 PM
  4. Dirction / Step lines!
    By bigal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2005, 08:51 PM
  5. electronic spindle switch
    By treemagnet in forum CNC Machine Related Electronics
    Last Post: 08-25-2004, 03:58 AM
