586,655 active members*
2,408 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > First photos of CNCFusion 7x** lathe kit (finally)
    Mar 2004
    174
    Hi all, well it has been a long time coming, but the final version of the kit is nearly complete and I thought you all might like to see some pics of it.
    There are couple pieces not shown:
    1. The Z axis bearing block, which will mount to the plate you see near the tailstock.
    2. The Z coupling.
    3. The X axis nut mounting block that goes under the cross slide.
    4. Adapter bushing for the X leadscrew.
    5. Locknuts.
    The Z axis is direct drive, while the X axis uses timing pulleys. Six holes will need to be drilled and tapped for M6 cap screws. This is for CNC only, no manual control, (although you can remove the kit for manual use). We highly recommend removing the carriage. The rack and gears in the carriage produce considerable friction. The saddle slides easily by hand without the carriage in place.
    Z axis ballscrew is made by Thompson, the same ballscrews we use for the X2/X3 kits. The X axis uses a Thompson XC Series anti backlash, self compensating lead screw.
    The following tool list is recommended/required for installation.
    TAP WRENCH $9.29 - recommended
    5mm DRILL $2.46 - required
    M6 TAP $5.95 - required
    Transfer Punch Set $7.95 - recommended
    C-Clamps $9.99 - recommended
    Access to a benchtop mill such as the X1 or X2 would probably be very helpful, but is not required. Along with the installation guide, we will be documenting a mod that can be done with an X2 mill to increase X travel.
    We are shooting for a late June release date. Also the kit for larger 9x20 series lathe will be nearly identical to this kit, so hopefully that one will be ready shortly as well.
    questions?
    Cheers,
    Michael
    Click on images for larger view.
    www.cncfusion.com CNC kits for Sieg mills and lathes
    Nov 2007
    616
    VERY nice!! What's the projected pricing for the kit?
    Mar 2004
    174
    Thanks Blades. We don't have a firm price yet, as I haven't gotten volume pricing on the X leadscrew yet, (which is the most $$$ part). But I can't see the kit going over $500.
    I will be fitting and testing it over memorial day weekend.
    cheers,
    Michael
    Apr 2009
    144
    Quote Originally Posted by wisp View Post
    cheers,
    Michael
    All right, June is over, prices????
    JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
    Joes 4x4 R&P in progress
    May 2005
    1662
    Hi Michael
    Nice kit. Have you considered offering optional add-ons for those wanting to have thread cutting ability ? otoh those fittings (thinking encoder setups) might vary depending on choice of control.
    Happy 4th
    regards
    jeff (a happy cncfusion customer)
    Mar 2004
    174
    Hi all, I snapped a few quick pics of the kit with it installed. I will try to get some steppers hooked up this weekend and post some video of the lathe in motion. If all goes well, I will be shooting a little install video, and instructions next week. REALLY going to try to get these ready ship in Nov.
    Here is short video CLIP tuning the screws by hand.
    PS: ignore the ugly ballscrew, it was just a scrap one I laying about. Production ballscrews will be nice and shiny
    Let me know if you have any questions.
    Cheers,
    Michael
    I took this one just for fun. The entire 7x12 lathe fits on the G0704 table....
  1. I have the CNCFusion Kit for the X3, Now what?
    By Ninhil in forum Benchtop Machines
    Last Post: 09-10-2007, 02:15 AM
  2. Finally got a lathe!! 2 Q's
    By DennisCNC in forum Uncategorised MetalWorking Machines
    Last Post: 06-30-2007, 11:26 PM
  3. CNCFusion Kit Install photos
    By Jay C in forum Benchtop Machines
    Last Post: 04-26-2007, 10:30 PM
  4. CNCFusion 9x20 lathe conversion?
    By thumper650 in forum Mini Lathe
    Last Post: 04-24-2007, 07:00 AM
  5. Got my new lathe today, finally.
    By Ace12GA in forum Mini Lathe
    Last Post: 12-29-2006, 10:44 PM
