586,363 active members*
3,233 visitors online*
    Oct 2005
    420
    VQC-20/40B part manaul
    Hello,
    I was wondering if anyone on here might have a parts manual for the above machine? I had a ballbar test done yesterday and found that there is some mechanical backlash somewhere but the tech did not think the ball screw was an issue due to the data output from the ballbar. He thinks I should look into the thrust bearings as the answer. I would like to look at a breakdown before I start taking apart the machine. Even just a scan of X and Y axis (not the whole book) would be great.
    Nov 2014
    12
    Hi i have vqc 20 40 with cam m2 control because of battery down all params gone.and i dont have param list would you pls send me params by taking photo or list.and i can send you machanical part list thanks in advance
    Dec 2007
    300
    Re: VQC-20/40B part manaul
    Call Mazak parts dept. Have your serial number and you can get any manual for $75.00
    Oct 2003
    321
    Hi gokusan,
    send me your mai on : [email protected]
    best regards
    mazak-user
  1. cant get rid of solidcam from a part created internally within the solidworks part
    By Nava in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-24-2013, 01:05 AM
  2. RFQ for part to mount on picatinny rail and sheetmetal part
    By JAW in forum RFQ (Request for Quote)
    Last Post: 08-23-2012, 02:00 PM
  3. Newb ? - CAD Part interference & mating part dims
    By pabmartin in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2009, 07:18 AM
  4. sheetmetal part? flatten a rolled part?
    By Rich05 in forum Solidworks
    Last Post: 08-13-2009, 04:22 AM
  5. Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum MetalWork Discussion
    Last Post: 03-15-2008, 12:35 PM
