Hi guys,
I have a Taig CNC mill and have a home-made flood coolant system. I have been using a submersible pond pump to drive the coolant out of a 5-gallon bucket. I've used this setup for a while with no problems.
For a couple of weeks I had been working in plastic and hadn't used the coolant. I was doing some cuts in delrin and I decided I would use the flood coolant for kicks to see if I could maybe do some deeper cuts. I started the flood coolant and it went fine for a few cuts. At some point the motor stalled out and I was only cutting 0.1" DOC in delrin with a 1/4" end mill. At first I thought maybe I was just cutting too much so I dropped it down to 0.05" DOC which I have done many times before in delrin without any issues at all. I started it back up with the flood coolant and it went fine for a few seconds but then stalled out again. Hit the e-stop and finally made the connection - I started it back up again with no flood coolant and it cut fine for hours.
That was a few days ago. I cleaned out the filter and made sure there wasn't a lot of buildup in the reservoir and everything seemed fine. I ran the coolant for a while and alone it has no issues at all. I gave it another shot and again it cuts fine for a little while but then the motor stalls.
I really have no idea what is going on. Could it be a problem with ground? Maybe the coolant is transferring a charge to the spindle and the motor is losing voltage? I would think that if the issue was with the power limitation on the garage circuit then I would trip the breaker. Anybody have any ideas?
Thanks for any help,
Matt
